Adam's In & Out Spray
joshcaro
Debating on what to buy from Adam's I pondered over In & Out Spray. It seems I never hear anything about and it looks like a potentially good idea. Has anyone used this stuff and for what?
Im thinking it looks good to use for wheel wells, maybe plastic bumpers?, plastic grills, grainy cowlings underneath wipers. Has anyone used this product for any of these uses, or for anything?
This is a product that I originally overlooked. I never thought much of it. I ended up winning it in one of the monthly contests and I like it a lot now :D
The best description of this stuff, and if you only read one thing I think this is the most important... its like spraying a temporary clear coat on anything you want.
The aerosol can has a very fine spray and you don’t want to wipe the surface after you spray it. There is no need to wipe it anyways.
If you spray too much of it on, I think it will collect dust a bit faster than normal but you will have to find out how much you need. Just be aware of that.
This stuff is too good for wheel wells :D. It EXCELLS on plastic grills (seconds to dress the grills instead of 20 minutes lol), the plastic under the wipers, plastic bumpers, and its really easy on any plastic you don’t normally dress. My black mirrors are kind of glossy and I don’t dress them normally because it doesn’t come out very even, but with this stuff, it looks good.
I never tried it in the rain, but it does have decent durability. You will probably need to reapply it if you wash that area really well during a normal wash.
PROS:
Very easy to use,
Decent durability,
Adds a ton of gloss to anything
CONS:
Can be a dust collector
NEUTRAL STATEMENTS:
You need adequate ventilation while using this if you use a lot (since its an aerosol),
Neutral smell (not bad, not good)
Overall, I would recommend you try it. It’s a product like no other.
I've used it numerous times and love how it sprays so broad and abundantly. Very ideal for interior vents. I've even used it on my grill. Be sure to clean the panel first. I have to check on durability, but this stuff is perfect shows!
