First off, my car just got back from being repaired by a body shop for a keyed door. It was nice of them to use a filler to cover up there work on 2 doors! Really nice after researching them, talking to them, just like every other shop here in VA.
Anyways, perfect time to do some quick testing and wish I took some pics but time was short (it was under 20 degrees here. I started with a quick 4-1 wash and clay. Focus wash polishing a few spots around car and correct body shop nightmare.
I will say that the Brinkman light might be my best tool outside of my PC now. I used it to check polish breakdowns, general lighting in a darker garage and check for correction. I love it and will use it on all my correction details!
I tried 105 on my PC with a 5.5 cyan pad. My 2007 Nissan Black Pathfinder has stupid soft paint so I did a test spot and tried to figure out all the madnesss. I couldn't dial in the working time on this product and it flashed super fast and was an extreme pain to come off. I primed the pad then used 2-3 pea sized dots and started on speed 6 slow pressure small working area. I was left with a ton of hazing, micromarring and some correction. I tried a 4 inch cyan pad with better luck but think my paint is to finicky and soft for 105. I'll stick with Powergloss as needed and will try 105 with a few other cars I detail. Any input on how to use 105 of soft paint with a PC? I think it's better suited for hard paints! I don't think 105 is needed on every detail, every car as most posts around here show. I think you can accomplish a lot without having to use it by using other products. Why use 105 if it hazes panels worse than other compounds? I find it almost absurd that people post on here that you can finish lsp ready with it. I'd like to see some proof of this on black paint after IPA wipe!
Now drumroll please...205 might be my favorite product besides IP/FPII. My paint loved it and it was sooo easy to use. Not only does it finish well but it has some CUT! I used it with a 5.5 white polish pad and it cleaned up everything. IPA wipe and beautiful finish. I can compare it to my use of IP that it almost cuts similiar and finishes so nicely on soft paint. I used it to remove serious holograming fromt the body shop. It removed a ton of swirls too. I ran out of time and will use my new bottle of 85rd to finish everything out. I doubt it needs it but I guess I can jewel now.
In summary, 105 is a pain (need some input from you all), if your on the fence about 205 BUY IT! This is going to be my new 1 stepper for myself to just use as maintenance throughout the year and every once in awhile use 85rd to get that extra pop. BUY the BRINKMAN! It is cheap and effective.
Also I miss my regular hose wash. I used my trusty DP 4-1 wash and found my paint to be not so clean after 2 cleanings under the lights. I don't know how some of you only use rinseless as it doesn't clean everything including tight spaces. In my opinion rinseless washes have their place but do not replace a traditional wash.
These are just my opinions and findings and would like to hear some input on 105 from those of you who have used it with a PC successfully. I have about a decade of experience with the PC and other polishes. This one is truely :think:
