A novice comparo test - 4x Griot`s, Sonax, FK
Oneheadlite
First off, let me take this opportunity to thank our members that deliver the really scientific comparison tests. This will not be one of those. :lol:
Think of this more like a Go/NoGo gauge. Due to my commute and putting family time first, I can`t say I`ll stay consistent on how often the car will get washed, though honestly I figure that`ll be part of the appeal. For testing, (and to keep it "in the family"), I`ll only be using Griot`s Brilliant Finish Rinseless Wash.
I`ll try to provide updates as I observe anything noteworthy.
What`s the test? Took the chance to try out a few things I`ve had sitting on the shelf that I`ve been curious to compare. Divided my roof into 7 sections and will be comparing:
1: Griot`s Liquid Gloss Poly Wax - Applied after cleaning up the section with Griot`s Correcting Cream
2: Griot`s Ceramic 3 in 1 Wax - Applied over Griot`s Finishing Sealant
3: Griot`s Finishing Sealant (standalone)
4: Ceramic Speed Shine mixed 50/50 with Sonax Brilliant Shine Detailer
- Applied after cleaning up with Griot`s Correcting Cream
5: Ceramic Speed Shine - Applied after cleaning up with Griot`s Correcting Cream
6: Griot`s Ceramic 3 in 1 Wax - Applied after cleaning up with Griot`s Correcting Cream
7: FK1000P - Applied after cleaning up with Griot`s Correcting Cream
You may ask:
Why products over Finishing Sealant instead of bare naked paint?
Since it`s not as easy as I`d like to be able to spend the hours required to do a full correction/application, I`m toying with doing touch ups with an all in one and topping with an LSP. More specifically, using the method I learned about here from Cruz`s car wash where you: do your AIO and let it all haze, then apply a spray of your LSP to the panel and buff it all off.
I did this last summer with my Wife`s Mom`s car using Blackfire One Step and Sonax PNS and was really happy with the results. Why not just keep doing that combo? A: Out of PNS. B: thanks to too much reading on here, I`ve got way too many things on the shelf to try and too little time to use them. :D
Why would you mix Ceramic Speed Shine and Brilliant Shine Detailer?
A while back, people talked more about doing mixes of BSD with V07 spray sealant to help cut down on the grabbiness of BSD. I figured - Hey, I don`t have V07, but I`ve got this Ceramic Speed Shine that`s pretty sweet, why not? Are they compatible? Maybe Probably Not? But I bet it won`t rot my roof off, so why not give it a shot?
As mentioned above, I didn`t go super scientific setting it up. No tape, just used reference points to set up my test areas. For my own car, I didn`t really want to leave any glaring lines where one section was polished vs AIO`d. I figure when it`s all over, it`ll be plenty easy to blend it all back together.
Observations during application:
Liquid Gloss Poly Wax was super nice to apply/remove. You forget how little work a thinly applied liquid sealant is! Also, nary a drop of sweat shed worrying about high spots.
I applied FK1000 too heavily by hand, so buff off was a bit finicky. Again, did that to myself.
Shortly after applying everything, I found the BSD mixture was eager to separate/congeal? I only mixed like an ounce of it in a little 3oz pump sprayer, so no loss there.
Ran out of lunch hour, so I`ll wrap it up here for now. I`ll jump on Tapatalk to get a photo or two up.
More updates to follow shortly - There`s been pollen and rain since the test started. :D
