Don
Darth Camaro 12/27/15
I used a “New to Me” cleaner that I learned about on You Tube, on one of APEX Detailing`s videos. The cleaner is not sold in stores, or online (not exactly). It is a home-brew concoction using two VERY common cleaners – laundry detergent (without fabric softener) and an APC (I used Purple Power, since it`s what I have on hand).The idea is to use about 2 ounces of laundry detergent and about 1 – 2 ounces of APC, in a 32 ounce bottle, then filled the rest of the way with water and mixed. I watched the video about him cleaning some NASTY interiors (non leather) several months ago, but since I haven`t been in a `detailing state of mind,` and don`t really LIKE doing interiors, all I`ve used it for is cleaning the soap/dirt rings out of the bathtub (which it excels at, it literally MELTS the dirt away).
My wife had mentioned that she would like to have the interior of her car cleaned, so yesterday, instead of working on the Camaro, I did the interior of her Escape. Starting with trash clean up and a solid vacuuming, I got to work. Then, starting with the driver`s door, I worked my way around the car, doing one area at a time. Door sills, followed by that panel for that door. The only tools `required` were two microfiber towel, one `wet` and one `dry,` a 2” paint brush (I don`t have detailing-specific brushes and I`m to cheap to get some), the bottle of cleaner and a bucket of fresh water to rinse the brush and `wet` microfiber cloth after each section (let me tell you, the `rinse` bucket got surprisingly dirty).
Her Escape has a light gray/tan interior and it really shows dirt. As most detailers know, a large portion of the dirt and grime that collects on interior panels are body oils, sweat and dirt. Let`s think about that real quick...laundry detergent was SPECIFICALLY DESIGNED to deal with exactly that kind of dirt, and remove it from your clothes. So why wouldn`t it work on interior stains?
I started by spraying the panel with the cleaner, to give it some soak or dwell time. Then I sprayed a shot of cleaner into the brush and started scrubbing. This mixture does foam up a little and in some areas, you could see the foam turning a light brown. Once I was finished scrubbing, I took the `wet` microfiber cloth and wiped off (rinsed) the panel, then I followed up with the dry microfiber. The results were impressive, and it didn`t take a lot of time or effort. Even `undressed` the panels looked great. As a bonus, the scent from the laundry detergent made the whole car smell pretty good. I would call this product “test” a success.
