MnRiverman
OK, I'm looking for something stronger than the SMR, and I was told to get this, 3Mâ„¢ Finesse-Itâ„¢ II Finishing Material, 16 oz, PN 39003
Sounds good, right?
So I apply that with a cutting pad, then I follow that up with the SMR with a polishing pad and I should be set for swirl removal, with a smooth, swirl free shine.
Now, Can I use the SMR for dark colored cars on a white car? What's the worst that can happen? I don't want to have to spend another 12 bucks to use just on one car.
Then, I remember reading about a new Glaze by 3M, which I'm told is called "3M Perfect-it III Finishing Glaze 09377", but I'm looking on 3Ms site and I can't find it anywhere.
What is the difference between the Imperial Hand Glaze and what is listed above? I remember reading the Finishing Glaze will last longer, and is easier to apply/remove. I assume both are safe for fresh paints?
Then I plan on following up with 3M SCPW and call it a day. This is for my sisters Purple New Beetle, which needs some serious lovin'.
Thanks again guys.
- Anthony
Sounds good, right?
Thanks again guys.
- Anthony
