Congrats on a great Extractor..
I have had the same one for over 10 years and it has never failed to work really well..
- Need a Dedicated 20 amp circuit if you are running the heater all the time.. Use a 12awg extension cord if needed..
- I never used anything but water from the garden hose in the Water Tank, and never had an issue
- Be sure to get to know how the filter bag inside the Recovery Tank goes on and off because it will get full of gunk and have to
be emptied..
- The high pressure hose will get hot up there by the handle so watch out for that..
- Keep the big vacuum hose straight and not in any position where it can get kinked etc..
- Be sure to empty the recovery tank after you finish that job, and rinse it out.. The water will be totally black with dirt, etc., that was deep in the carpet before...
- Its on wheels so it is easy to roll around for the trunk area and if you want, you can do the Interior of most vehicles from one side..
- The stainless steel tools are big and heavy - mind how you use them inside and watch where you leave them..
- Learn how to Key the hot pressurized water onto the surfaces and remember that all the water you put in there, you have to
Extract it or it will take too long to dry, and could get down past the floor insulation..
- Sometime later, run some straight Distilled White Vinegar into the tank, let it work through the high pressure pump and hose, and through all your Extractor Tools to keep then free of water deposits..
- You will need to run some clean water afterwards to get all the Distilled White Vinegar smell out.. It wont last forever, be patient..
- Dont screw the circular lid on top of the Recovery Tank too tightly or you will have a hard time removing it..
- Watch the level of black water in the Recovery Tank, and empty it before it shuts off the vacuum from the machine..
- Clean the Floor Mats on the floor or a bench, know that the high water lift will want to pick up the whole Mat sometimes, so you need to hold down the top edge with your hand until you get past it..
- Use a Defoamer powder in the Recovery Tank to keep foam down as the recovery tank water is used to cool the motors..
- Be creative on how you use the tools in the car.. They are angled in a way so they will only work so far in a tight space..
Figure out different directions to approach the carpeted floors, so that you will make best use of the tool.
- The long stainless crevice tool will be able to get in places that the bigger tool will not, of course, so use it and find ways to
make your work more productive and fast.. Since its only a small area to spray and extract, it will of course not be as
powerful as the other tool but if you press down, you will hear the HP60 going up to the 3rd stage of its motor..
There you go !
Dan F
