#9 vs. Sonus Cleanser vs. P21s cleanser
kevmo327
Might be a dumb quesiton but if I want to prep the pain before using Klasse twins and after claying is there any real differance between the products liosted above?
I was going to give Sonus a try on the wifes car but wasnt sure if it was "the same" as #9 or not.
I am going to buy a bottle adn see what i think
I have substituted the sonus polish for AIO, since sonus is supposed to be safe to use prior to using a sealant. Looks great so far!
Aside from eliminating any possible sealant bond inhibition (which was not apparent when tested by David B), I don't think you'll gain much aesthetically from using AIO after sonus. Personally I haven't seen a difference.
-Raymond
Sonus and P21S are both pre wax/sealant paint cleaners. They basicaly do the same job as AIO. Using either of them before AIO is really not going to do any thing for you because they do the same job as AIO. #9 has more cut than the others and will remove minor marring if you have any. Than proceed to AIO and SG.
I'm sure somebody will come along and say #9 has fillers that AIO will just remove. True, but #9 also will remove minor defects.
