85RD - ultrafina - S40?
cheapshot
looking to try and get the most out a last step polish.
I have not used any of the above, which would you recommend and why?
It will be used with Flex DA.
You can't go wrong with any of those.
I haven't used any of those with my FLEX yet so I can't give you an educated answer.
I will use them and let you know my thoughts.
Troy, I bet your garage is filled with goodies. Wish you lived next door, I would just pull my car in and start sampling products. of course for a small fee!:D
let me know your findings.
I've not used S40 but I love the other two...though I tend to use them on the rotary more than the Flex.
I see they renamed ultrafina to ultra fine machine polish. Does anyone know if any changes were made to the polish?
Rasky, which do you prefer on rotary? cut? working times? finish?
Ultrafina is the UK version. I'm told they are the same thing though. I have both the UK and US versions but have not compared them yet...the UK pads ARE definitely different though.
I think UF is easier to use and has a shorter working time. I'm not a big fan of the long working time Menz requires, even though it produces excellent results.
LOL, who makes S40?
Rasky
Are there any other last step polishes that should be mentioned?
Has anyone used the new SSR1? How does it differ from the older version?
Do you think using the flex da with UF would make a big difference, instead of rotary?
The more and more I use the flex, the more and more I keep saying wow, this is much better then the PC.
Well after thinking it out, I now have UF sitting in the garage. I'll post after a few uses.
Has anyone used UF with Flex DA? If so what speeds?
What pad do you think would be best with Flex DA?
LCM blue
meguiars finishing,
3M UF light blue wavy one :)
Thanks
What brand is Ultrafina (UF)? Thanks.
Edit: Nevermind, I think I found it, 3M?
LCM blue
meguiars finishing,
Thanks
