I'm plotting my attack on the cobwebbing and other micromarring I picked up over the winter. I'm trying to stay within the means of my budget and use what I already have.
Ideally, I'd like to pick up some #80 to use after the #83, and then go to AIO, then SG x 3, then a carnuba.
Can I use #83 with a cutting pad on my PC, then go to #9 with a polishing pad? Will the #9 be aggressive enough to remove the hazing that the DACP will no doubt create?
I also have some 3M SMR. What are the thoughts of using the SMR instead of the #9? Will the AIO remove the fillers from the SMR? I'm not big on fillers, as I'd rather remove the swirls than cover them up.
TIA
TIA
