#80 (Speed Glaze) vs. #82 (Swirl Free Polish)
benpocock
I've had #80 for a while and have just added #82 to my collection and notice that they both share the same cutting ability (or so the label on the bottle says). So what exactly is the difference? I realise #80 has some protection in it for freshly painted surfaces, but is that it?
On initial use I've had more sucess with #82 than I have had in the past with #80 - is that because #82 has fillers (not that it would bother me if it does?)
Ben
Ben
Ben
Are you sure the label says the cutting ability is the same :confused: I was allways under the impression that #82 SFP was less agressive than #80 SG.
Andrew
Ben
Andrew
Well I think this must be the old style bottle as this is what I see when I'm looking:
Ben
Ben
Actually I think 80 would have more fillers than 82. I have used 82 with great success. It is a very easy polish to use with a rotary, wipes clean with no fuss, and works real well after DACP. I tried 80 but I still prefer 82.
Ben
NHBFAN said:
I find #80 and #82 to give similar results.
Me too, but #80 breaks down more quickly (hence the inclusion of 'speed' in the name) and has a more wet looking finish, while #82 is more clear. Not huge differences though.
Mainly I use M82 after M80 to produce a crispier surface without much micro-marring induced by M80 with DA. I haven't tried using M82 with rotary though...
Referring to the pic of the two bottles, the label on #80 used to incorrectly show its abrasive level as being lower than it really is. #80 is a little more aggressive than #82, but only until you work it a little while. Both should leave a ready-to-wax finish, but IMO #80 is more idiot-proof than #82.
Sorry to resurrect an old thread but... What do you mean by more idiot-proof?
I just used #85, #83, #82 this weekend, in that sequence, and i coudlve'nt have been more disappointed. The results were great ( but i think it was actually due to the wool pad), but wowww were they hard to remove. I think i caused more scratches by trying to remove it then i removed buffing it.
