#7 Between Wax layers
CleanMachine
I've been outside making my truck turn some heads again and I had an idea. I use DACP which I just finished with, VM then S100. I was wondering how #7 between the first, second, and third coats of S100 after they are cured ofcourse. I also plan on trying 26 between S100 coats for some warm depth. Any thoughts????
Thanks, Dave
I'm not an expert on the whole glaze-wax process, and haven't used #7, but I have the feeling that you can't "layer" glazes and waxes in general....
I have used the Meg's glaze a couple of times with good results. Since it is a filler, it needs to be applied with nothing between it and the paint to work properly. After that put whatever wax or sealant you want on top of it.
