Blackmirror
Who's got them? I read a lot about these pads and they look really good. I like the fact that you can use the outer part of these pads when polishing in tight spaces and contours! Anyone try them? How do you like it?
AudiOn19s said:Everyone's opinion on this will be different, but I've used the flat 6.5' pads and the 7.5' VC pads and I'll never go back to the flat pads again. The main reason I switched was because of issues with cutting into pads with the backing plate, velcro separating from the pad, ect...which often ment that I was sometimes throwing away pads after 5 uses or less because of wear issues. Since switching to the 7.5' pads I've had none of these issues becuase of the design of the pad and I've learned how to make them work very effectively for me with a PC.
