55 gal.drum water tanks?
ADR_454
hi all! dose anyone know how to make 55gal. drums work as alternate water tanks for a mobile biz?
Not sure what the drum your talking about is made of, but you should be able to drill a hole and thread in the fittings needed to hook up to a hose. Seal it and it should be ready. Does the drum have a lid?
Drums are difficult to keep in one place on trailer or in a truck(even strapped down).Find a Tractor Suppy Company in your area and buy a small tank.A 50 gallon tank will cost about $114.00 + tax.They also carry all of the fittings you'll need to hook things up.A float valve in also another suggestion if you ever have to hook to a customers water.
http://www.mytscstore.com/detail.asp?pcID=1
I've seen people using those blue drums you see everywhere. If you can get them for free then why not use them you know? You'd have to build a bracket system to hold one on its side.
Get some fittings,valves, etc and drill a hole in it. Same thing you would do with a actual water tank.
Most of the water tanks I've been looking have already have the fittings and they're ready to go.
