Bence said:The result would be: ...that's with my Bosch PEX270AE (12.5 cm BP, 4 mm throw @ 12K OPM). The high speeds break down the coarser abrasives (Riwax White paste or 1Z Pasta Intensiv) pretty quickly and LSP-ready.
Bence said:I'd buy the Bosch definitely. It is the pro version of mine, but the general architecture is basically the same. ... The backing plate doesn't spin freely, but it doesn't have forced rotation either. Sort of a damped turning action.
Bence said:The DW is clumsier, because it has only one grip on its top. And although some manufacturers use gel pads to reduce vibration and fatigue, grabbing a tall tool on its head is not especially comfortable for me. It behaves tippier than the better designed Bosch.
Bence said:I still would buy the Bosch. The 1 mm orbit difference, plus the better handle design is enough for me. The 3 mm orbit is definitely enough but slower than a 4 mm.
ZoranC said:Again, it is not speed of "removal" I am after, I have other tools for that task, it is which fine will be leaving finer finish.
Also, it is not 3mm vs 4mm. It is 2.4mm (3/32") for DW (if I am reading their specs correctly) vs. 4.8mm for Bosch which would make Bosch orbit diameter twice bigger, plus I already have Festool that has 5mm orbit.
I have a feeling answer will be in the pudding (my favorite excuse to buy more tools). I can buy DW in my neighborhood for price even lower than online so I might try that first.
sneek said:Mike Phillips has a porter cable sander that he used as a polisher (not the 7424) and i don't think he said it was good, but i cant find the thread on the old MOL.
Bence said:I got it for the first time, believe me... But in the end I think when you have the speed, you have the finish quality as well.
Bence said:In this case, the differences are even bigger, so the DW might be a good choice for you - especially for that price.
Bence said:In Germany, DW has a new orbital which has a switchable 3 and 6 mm throw, and the architecture is similar to that of the Bosch.
