~One manâ€â„¢s opinion / observations~
Temperature conditions:
These are the temperatures and conditions that are relative to the application of car care products; the most important is the actual surface temperature of the vehicle. The other things that will have a direct bearing on this is the humidity as this will effect the cross-linking (cure) time, excess humidity will also affect â€Ëœhowâ€â„¢ a wax or sealant dries (i.e. it may cause hazing or clouding of the surface)
The other climate related condition that should be avoided when applying car care products is direct sunlight, as this will dramatically increase the surface temperature compared to ambient temperatures causing the product to dry prematurely and may render it ineffective.
1.Surface Temperature (Actual surface temperature of the vehicle)- 60 â€â€œ 80oF products will work well within a much broader temperature range, (50° to 90° F) but the best results will be achieved in the 60° to 80° F range surrounding air temp (ambient or room) must be 55oF + to ensure the minimum vehicle surface temperature of 50oF(recommended as a minimum by most manufacturers)
2.Ambient Temperature (Outside air temperature) 35oF+ for vehicle washing
3.Relative Humidity (Moisture content of the air)- RH 50% +/-10%
4.Inside Air Temperature (Room Temperature) 70 â€â€œ 75oF +/- 10oF and 50% relative humidity +/- 10%
5.Air movement or windy conditions will increase the evaporation rate but potentially make some products more difficult work with, especially sprayed products. Perversely this can lessen wax / sealant drying time.
In summary, the ideal conditions for the application of car care products; cool and dry, away from direct sunlight, a surface temperature between 60° and 80° F, 50% RH or lower humidity, and a light air movement.
~Hope this helps~
Knowledge unshared is experience wasted [each one / teach one]
justadumbarchitect / so I question everything/ JonM
