4 inch spot pads...need help please!
mc01ta
I have a Porter Cable polisher and looking to buy 4 inch spot pads. Trying to decide ordering between autogeek and top of the line. Autogeek has a 2 3/4 adapter and top of the line offers a 4 inch pad holder.
Also trying to figure out what 4 inch pads I need. I have pretty much everything in 6.5 size. I think i'm going with 2 orange and 2 yellow. Not using 4 inch for anything else.
I also need something stronger than OC. Looking at H-Temp EC or HC. Which one would you pick to use with the PC and 6.5/4 inch pads for correction stronger than OC?
Is there current discount codes for autogeek or topoftheline?
Thanks!
I believe the code for Autogeek is autopia and TOL does not offer any discount code.
I have used the 4" cyclo pads and they work well on the PC with the proper backing plate.
mc01ta- Yeah, I usually get by just fine with the old Cyclo brands.
Orange pads sometimes seem unstable at higher speeds, so I turn it down to 5 with them. The green and white (Cyclo) pads work fine at speed 6.
The Sonus SFX 4" pads seem to work well too.
Forget who I got my backing plate from, but I think I have a TOL one that works well.
I'd get the HT EC. The added cut might come in handy and it finishes out almost as well as the Heavy Cut. Both require a follow up pass with something milder anyhow.
