4 inch pad confusion
joec42
I'm planning on getting some 4 inch pads for the PC and am confused about all the varieties/variations.
I see a bunch of different types of 4 inch pads:
Lake Country 4 Inch Low Profile pads, no dimples
may only be available in orange
Lake Country 4 Inch Foam Pads Low Profile- Made of high quality foam, these pads have hook & loop backing all the way to the edges. The benefit of
4 inch dimpled pads (CCS) with a constant pressure back (Technology)
4 inch, CCS Technology, Spot Repair Pads
Thick pads with dimples (CCS Spot Buffs 4 x 1.25 inch Pads)
Spot Buffing 4 inch pads - 30% thicker than the Low Profile Spot Buffs!
Thin dimpled pads (CCS Low Profile Spot Buffs 4 inch Foam Pads)
may only be available in yellow or blue?
CCS Spot Buffs 4 inch Foam Pads
I'm ignoring the Edge and Cyclo variations.
This will be used on several Hondas (2002 Blue Pearl, 2004 White) and a 1991 Mitsubishi Black and 2006 Mitsubishi Grey Pearl.
I'm thinking of getting the sample package (16oz) of IP and FPII or maybe using the ZPC that I already have.
Any recommendations for which 4 inch pads to use?
Also, regarding backing plates: I see the yellow 3.5 ( 3.5" Dual Action Flexible Backing Plate- porter cable 7424 or 7336 hook and loop backing plate 3.5 inch. ) and a black 2.75 ( 2-3/4 Hook & Loop Backing Plate ) plate. If I get the 2.75 I can also use it with the 3.5 PFW pad. However, is the 3.5 yellow backing plate a better choice for the 4 inch pads?
Thanks.
