4 Day Detail...My Detailing Rigg Perfected to the T. Get some Popcorn
This took me 4 days but I took a lot of breaks as I wore myself out on this one.
This is my personal ride, my detailing rigg 04 F150 Xtended cab, 6.5' bed of nothing but swirls and scratches. I bought this truck used back in January and did this correction about 3 months ago.
I did everything from filling in paint chips all over the front end, to wet sanding multiple scratches on every panel of the truck and of course removing swirls on every square inch including the roof.:chuckle: :waxing:
I will not post every single pic I have of the process, just the basics.
Sit down, grab some pop corn and enjoy the show.
Process: too long to list everything.
The usual wash, claybar, rotary with white pad and Menzerna IP X 2 passes in some cases more passes. Wet sanded scratches and followed up with PC. Followed up with the PC and Menzerna IP then two coats of Zaino Z5 to top it all off.
First for the paint chips on the front end.
Some of the pics are tough since the camera had a hard time focusing on the bumper and not the reflections...
before, below the fog light chips
after, fog light paint chips filled in and buffed down
before, above fog light bigger chip
after, still faintly noticeable, but not bad
Here's the condition of the paint before
up close over the fuel door
This is after one pass with Makita Rotary, LC White Pad, Menzerna IP @ 1500, still some swirls left over.
After a second pass with the same set up, it's perfect.
This is the Driver's Side door with some Sanding marks
Sanding Marks up close
Sanding marks and swirls gone, sorry I turned off the hollogens when I took this pic
Hood swirls before
after
hood swirls before
after, you can see from the slight purple haze that it still needs to be finished down with the PC....
oopps, accidently copied the same pic twice, I've now corrected it....:har:
Many more pics to come, and after pics in the sun.
This will be the shiniest, most deep, wet and glossy reflective F150 you'll ever see.:woot:
here's some of the rear door on the drivers side, you can already see a difference between it and the bed panel.
after two passes
Of course there was much more that took place then those few sanding marks and chips on the front, but I think by now you get the idea of what the entire vehicle condition was like.
Now onto the glamour shots outside in the sun with a little cloud cover.
I put these headlight in, they are aftermarket and look freakin good too. IMO:D
All the paint chips are gone.
still more pics to come
Josh is my new favorite detailer! hahah. excellent job man! red is in my book just as bad as black in some cases. never can tell where the swirls are :(...proven to be one of the greats yet again.
Cheers.
Adam
Not bad for a tailgate....
back into the garage
This is where a key mark was, you can still see a slight reminent of it after wet sanding and buffing.
a buddy of mine came over to hang out
Next are some pics, literally 3 months later in the rain. Beading like crazy after over an hour of raining with only 2 coats of Zaino Z5.
Nice to see Zaino does what it says it does. This is why I use it.
up close shots of the beading
works on headlights too, I also use it on my windows
and bed side panels as well
It's nice to know all that work paid off.
Thanks for looking,
Josh
Josh, Excellent correction on the large amount of red paint. What a shine! Its nice to have your rig all polished when you arrive at a clients place for a detail. Really shows your level of professionalism.
Thanks for posting!
The lights with the black grill are totally transform that truck. Wow...
Now on to your work. Awesome, you really brought that around and its nice to some of your other skills (which are amazing as well). Loved the right up, knowing a quality detailer was pulling out the stops on his baby.
Great thread, great pictures, great truck, great write up... you get the idea
Thanks Josh
i havent had any luck with touch up wetsanding repair.. i can never get the touch up flat enough or if i do, the paint comes off from the polishing then im back to no paint on it. any pointers you can give me? you did a great job
That's some really good work! Red looks SOOO good when it's taken care of properly. Those headlights are bad@$$! It really makes your truck stand out from the rest of the crowd. When I first saw it and before reading that they were aftermarket, I was thinking in my head "wow, I never knew Ford came with such nice projector headlight housings from the factory."
Wow, you have detailed thoughts. I was thinking more like, "Man those lights look nice"... :woot:
Absolutely incredible work. Top 5 details I have ever seen and possibly the best. Unbelievable work on the chips and I also love the headlights. I would also like an idea of your process on the chips.
-Frank
Looks like it just rolled off the showroom floor. Stellar work! :2thumbs: And the headlights are the perfect touch, subtle and classy. I would also like to hear more on your chip touch-up process.
Thanks for sharing! :kewlpics
