4 and 1 plus PwS
shadybreal
I just received my 4 and 1 rinseless wash today, and really wanted to give it a try. I was busy moving all day, but was able to use it on my wife's car tonight.
Process: (Exterior only except for interior windows)
Wiped down interior glass w/ 4 and 1 then dried
Washed extire car w/ 4 and 1 from top down, but drying after each two or three sections
Washed rims, tires, and wells.
Applied tire shine (wet and protect) to tires and wells
Applied All Season dressing to exterior trim
Polished w/ PwS w/ PC and yellow Edge pad (techinque learned from Justin)
Aquawaxed all paint and exterior glass
Pictures are pretty bad since it was dark and I was in the garage w/ decent lighting. You can still get the idea.
A few of the things I used. I actually only wound up using a few.
I'm surprised you used such a strong, aggressive pad with that very mild polish. I've heard that most used a gray or maybe white pad with that??
I got this technique from Justin30513. I used the yellow pad at 4 to work in w/ moderate pressure then I went up to 6 and just let the PC glide across the paint w/ no pressure. It really works great since the PwS isn't too aggressive. Once your done w/ using the PC on 6 the polish practically disappears. Very easy removal.
Looks good bro! Glad you were able to get your 4-in-1 that fast. Two days right?
Looks like your ShMitt has got some real use too!
