Brian_Brice
This thing has never been correctly polished, whoever did try to polish it apperently didnt break the polish down completely so it left product trail all over the thing. i polished driver side today will finish tommorow.
i washed the roof down with megs apc and a brush. lots of stains didnt come off that synthetic surface.
ohc sb pad via rotary 1500rpms till i got tired and switched to pc yellow lc and oc. this stuff never ceases to amaze me how hard it is to work on, let alone when someone else has already screwed it up. i did a test section right in the middle of the sunlight so hopefully you can see what im dealing with in this pic.
i do not like using synthecs on gelcoat/fiberglass/whatever other material boats and rvs are made out of. prime was applied very thin as usual/still a pain to remove. only in spots though for some reason. i don't like having to qd to remove an lsp but for some reason every time i work on these i have to.
It was dark when i left so i will have a better full pic tommorow.
