2010 Infinity FX35, D/A MF correction, Opti-Guard protection
Bobby G
by David W. Bynon
<font size="1">Copyright©, 1999-2002, Autopia Car Care -- All Rights Reserved</font>
Use only 100 percent cotton terry cloth toweling on your paint. Some people recommend cotton diapers, but they can damage your paint. The nap of a cotton terry cloth towel protects the finish from particles caught between the surface and the towel. Beware of synthetic blend towels, too. Synthetic blends may scratch your surface.
Refrain from turning your application towel over to its other side to apply a different product. Some ingredients might soak through, changing the complex chemical balance.
If you should encounter streaking:
1. Make sure you're not using too much wax. A little Carnauba Wax goes a long way. A thin coat is all that's required.
2. Be sure to wipe down with a clean terrycloth towel that has not been treated with sizing.
3. Warm and re-wipe the car’s finish. Brazilian Carnauba is hygroscopic. The natural effect of water, moisture and oil can be over come by allowing the finish to warm in the sun for a few minutes, followed by a brisk wipe down with a clean towel.
4. Store your Carnauba wax in a cool dark place preferably refrigerated (do not freeze!). Warm waxes to room temperature before using. Paint surfaces must be above 65 degrees for wax to bond.
Infinity FX35, D/A MF correction, Opti-Guard protection.
I did this one a few weeks ago but haven't really had the time to post the pics. The vehicle was actually in pretty good shape but ended up needing a 2-step to get the correction level we wanted.
Process:
Wash - Foam bath with CGCW and 2BM
Wheels - Sonan Full Effect and various brushes
Tires - Optimum Power Clean, dressed with Megs Hyper Dressing 3:1
Clay - Megs mild clay and ONR as lube
Paint correction step 1 - D300 and MF cutting pad on the GGDA
Paint correction step 2 - 106fa and tangerine LC foam on the GGDA
Coating prep - Foam bath/wash with CGCW and OPC followed by IPA wipe down
Glass - Megs D120
Exhaust tips - Optimum metal polish
Trim - 303 Aerospace Protectant
Paint Protection - Optimum Opti-Guard
Sorry, not a lot of pics as I was under the gun on this one (Impala waiting)
Before pics:
Some DISO could also be seen along with some light webbing.
All taped up
After:
I thought the grill was pretty cool. :)
As always, thanks for checking out my work. :)
Rasky
