07 Camry Wax Questions
07yotacam said:
Planning on using Meguiar's NXT on top .... What can I use as a good coat underneath the NXT ???
Thanks,
Mike
I'd clay the car to start then polish and top with the NXT
Thanks,
Mike
Not much, seeing as how the NXT's solvents will probably adversely effect whatever you lay on before it. You might want to try topping the NXT instead.
Beemer's suggestion is a good one. Clay is definitley in order, as well as a good cleaner/polish.
Another suggestion, maybe apply PB EX or some type of high quality sealant first then top with a quality wax of your choice. NXT is a decent over the counter wax, but there are others out there depending on your paint and color that might look better. You will have to try differnt waxes to find out which one works best.
