imported_Grouse
00 Tundra, Polish Seal and Clean. This vehicle had never been detailed. It required more than just a polish. I ended up doing a light cut with 106ff and finished out with 1z metalic polish.
In the first set of pics you can see the heavy water etching, swirling and marring.
After Claying, taping and now checking paint with halogens, Leds and sun gun.
Some work with 106ff and 1z metalic polish. To be truthfully honest, it only removed about 60% of the marring.
You can see the difference between the two panels. Left side is 106, right is nothing
Here is the difference between a sungun and a set of halogens. As i said this only removed about 60% of the marring. You can see some of the deeper marring remaining around the sungun light. If you look at the halogens they don't show the marring. The truck was used to build several homes. It would likely take a couple more passes with sip or another heavier polish.
Afters
interior
Afters
interior
