Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Hybrid View
  1. #1
    Join Date
    Jul 2019
    Posts
    7
    Post Thanks / Like
    Rim Coating Process
    Hi to all...
    I have received my new Rims and also bought IGL Wheel Coat to apply to them. Unfurtunaly my tires will be here next week so i will have to wait to mount them.
    Is it a mayor risk to apply the coat before they re mounted on the tires? Will i loose my work?
    Thanks in advance...
  2. #2
    Join Date
    Sep 2019
    Posts
    378
    Post Thanks / Like
    Re: Rim Coating Process
    From what I have read about wheel coatings being applied prior to tire mounting is you run the risk of the balancing weights not adhering properly if your wheels are coated prior. I would get the tires mounted first
  3. #3
    Join Date
    Mar 2012
    Location
    Reisterstown Md.
    Posts
    3,075
    Post Thanks / Like
    We do it all the time, have them wipe down the area with straight alcohol before sticking the weights on. Did mine 3 years ago and no problem and no problems with any clients.
  4. #4
    dansautodetailing.com Stokdgs's Avatar
    Join Date
    Apr 2009
    Location
    NorCal.. Avatar = Swan Lake, Hallstatt, Austria
    Posts
    5,196
    Post Thanks / Like
    Quote Originally Posted by wcharon View Post
    Hi to all...
    The Tire Guys where I have gone for Decades, always wipe down that spot with I believe a strong cleaner, and then put the adhesive backed weight on that spot.. I have never had a wheel weight come off on my coated wheels, and the coating is still there..
    It will certainly be much easier to clean and apply your product before the tires are mounted..
    Dan F
  5. #5
    Join Date
    Dec 2016
    Posts
    26
    Post Thanks / Like
    My thoughts would be to apply it prior to tire install - sounds like there might be an issue with wheel weights - but for that just wipe all the wheel barrels down with IPA right before you bring them in for tire install.
    I would also expect a tire shop has knowledge on how to solve that issue - especially if you notify them up front.
  6. #6
    Mike The Guz's Avatar
    Join Date
    Oct 2013
    Location
    Lawndale, CA
    Posts
    3,757
    Post Thanks / Like
    I would wait. The installer is going to get the wheel dirty. I waited until my tires were installed and I had some clean up to do. Coated them after.
    Competition Ready Team 1929 Bentley
    1999 Silvermist Metallic Pontiac Grand Prix GT
    2002 Arctic White Chevy Camaro SS
    Likes BudgetPlan1 liked this post
  7. #7
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    86,995
    Post Thanks / Like
    Reading what Mike lambert/Stokdgs posted, I`d sure expect that cleaning a *coated surface* with IPA would merely clean the coating rather than compromise it and that the weights will stick fine to the actual coating itself.
    The Guz- *Will* the installer get the wheels dirty? The guys who do mine sure don`t...but I`m awfully particular about who does such stuff (and how they do it).
  8. #8
    BudgetPlan1's Avatar
    Join Date
    Apr 2010
    Location
    NE Ohio
    Posts
    2,668
    Post Thanks / Like
    Quote Originally Posted by The Guz View Post
    This approach has always worked well for me.
    Likes The Guz liked this post
  9. #9
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    86,995
    Post Thanks / Like
    I`m glad you folks are posting your experiences, which are getting me to rethink my plans...
    I would`ve waited for fear the mounting process would mess it up. But maybe I`ll just do another coat or so on the area(s) that might be affected.
    IF (huge "if" I fear..) the coating lasts as long as OptiCoat v1.0 has for me, having it *under* the weights will mean not having to redo when I get new tires..big plus for Yours Truly since the need for tires and coating happen to coincide this time around.
  10. #10
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    86,995
    Post Thanks / Like
    How *does* the, uhm..working life timing..go for others?
    Wondering whether anyone shares my "expect the coating to outlast the tires".
  11. #11
    Join Date
    Apr 2010
    Location
    NE Ohio
    Posts
    2,668
    Post Thanks / Like
    Quote Originally Posted by Accumulator View Post
    I can say for sure that on the Cayman the coating will far outlast a set of tires; from the service records that came with the car, the thing got its 3rd set of tires a week after I bought it at 12k miles (Thank You Porsche CPO!).
    My daily driver, not so much. Still on original tires at 55k miles, hadda recoat wheels last Summer at about 45k miles.
  12. #12
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    86,995
    Post Thanks / Like
    Quote Originally Posted by BudgetPlan1 View Post
    Goodness, I`ve never gotten even 25K out of a set of tires in my life! Between that and your Cayman your experiences sure span the gamut!
  13. #13
    Join Date
    Apr 2010
    Location
    NE Ohio
    Posts
    2,668
    Post Thanks / Like
    I`m used to it. Our`s is the house where every time an electrician or other fix-it guys stops by and digs into the inner working of the house, they usually start on the job and soon after say "Well, I`ve never seen it done like that before..."
    Likes Stokdgs liked this post
  14. #14
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    86,995
    Post Thanks / Like
    I`m used to it. Our`s is the house where...they usually start on the job and soon after say "Well, I`ve never seen it done like that before..."
    Oh man, that sounds familiar to me too
    We joke that when our builder said "Nothing says `quality` quite like [a house he built].." we didn`t realize it was a warning
    Likes Stokdgs, BudgetPlan1 liked this post
  15. #15
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    86,995
    Post Thanks / Like
    BudgeetPlan1- That little quip has gotten to be a catchphrase with the people we know IRL...like, every time anything initial-build-related comes up at anybody`s house. For us, it`s one of those "man, you just gotta laugh" (if only to avoid crying ) defense mechanisms.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Nova Evo pro coating and Nextzett glass coating any users out there?
    By William_Wallace in forum Auto Detailing 101
    Last Post: 11-24-2019, 08:26 AM
  2. Replies: 2
    Last Post: 08-28-2018, 11:52 AM
  3. Applying BEEDS CERAMIC COATING the process!
    By Beaver559 in forum Auto Detailing Videos
    Last Post: 11-30-2017, 06:38 PM
  4. Review: Pinnacle Black Label Diamond Surface Coating and Wheel Coating
    By Pats300zx in forum Detailing Product Reviews
    Last Post: 11-03-2013, 09:35 AM
  5. DP Coating Prep Polish and DP Glass Coating Review
    Last Post: 08-30-2013, 08:00 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
