Results 1 to 7 of 7
  1. #1
    Join Date
    Apr 2013
    Posts
    5
    Post Thanks / Like
    Looking for new system for Porsche paint (Arctic Silver)
    Hi All,
    I`ve been out of the game for a while but recently purchased a used 2010 Porsche Cayman in Arctic Silver. It has a decent amount of swirls in it when viewed under the right light. I did a couple of tests with some of my old, and possibly expired products (Megs DACP, Menz IP) and I did not have good results. (Maybe Arctic Silver has a hard clear coat?). Anyways I am looking for suggestions on a new system to try out since I need to replenish my supplies. The ones I have narrowed it down to are:
    Megs 105/205
    Optimum Compound II/Polish II
    HD Cut/HD Polish
    Blackfire SRC Compound/SRC Polish
    I will be using a PC XP with the usual array of pads.
    Any advice would be appreciated.
    Thanks
  2. #2
    I'm addicted to Shine Evan.J's Avatar
    Join Date
    Apr 2013
    Location
    Pittsburgh
    Posts
    724
    Post Thanks / Like
    Re: Looking for new system for Porsche paint (Arctic Silver)
    Megs MF cutting pads and the m105/205 combo
    If its hard you could even go with M101 or Menzerna FG400.
    Official Selected Team Member of the Air Force One Detailing Team
    Flex 3401 / Flex PE-8 / Rupes 21 / G110v2 / GG6" / Rupes 75E / GG3"
    Click and Like my Facebook Page
  3. #3
    dansautodetailing.com Stokdgs's Avatar
    Join Date
    Apr 2009
    Location
    NorCal.. Avatar = Swan Lake, Hallstatt, Austria
    Posts
    5,194
    Post Thanks / Like
    We can help better if you tell us the process you currently use/used on your last vehicle..
    What speed are you running your PCXP?
    What size backing plate and pad/s do you have and have used?
    Menzerna makes really great products, and some of their newer ones Menzerna FG400 for example have a really great cut and finish.
    I have not had great experience with the older, Optimum compounds you mentioned - but have had very good success with the Optimum Hyper Compound and Hyper Polish products.. Just forget using their sprayers, which kind of make a mess and put out too much product at the wrong place and time...
    Good luck with that beautiful Cayman !! I love that classic shape !!!
    Dan F
  4. #4
    Join Date
    Mar 2012
    Location
    Reisterstown Md.
    Posts
    3,075
    Post Thanks / Like
    I do a lot of Porsche, I use fg400 a lot on them, both foam cutting pads and micro pads. You may even be able to get it how you want it after that alone. I usually follow with rupes keramik or carpro reflect.
    Good luck they are nice cars!
  5. #5
    Join Date
    Apr 2013
    Posts
    5
    Post Thanks / Like
    Thanks for the suggestions.
    Stokdgs, my go to system used to be Menz IP on a Yellow pad followed by Menz FP on a white pad, then usually a glaze and Menz FMJ (I dont recall what speeds exactly). I was using the old Porter cable at the time which has since died so I will be picking up the PC XP to use going forward.
  6. #6
    Opti Coat Pro Certified Orinda Auto Detail's Avatar
    Join Date
    Feb 2012
    Location
    Bay Area
    Posts
    2,081
    Post Thanks / Like
    I have awesome luck with Porsche paint with the black fire duo. In the Orinda where the shop is everyone has a Porsche and we work on them all the time! Not sure what your going to use but I wouldn`t suggest something really aggressive. IMO its almost never need on those car as the paint responds really well to something mild.
    I got those results using Black fire finishing polish. How ever I was using Rupes21 which is a powerful machine. I think with a PC you could start with an MF cutting pad and something medium of your choice and get pretty much flawless finish on silver, and finishing polish would pick up the light hazing you probably cant see and really make the car pop. I know it`s been a while since you used a PC so don`t forget to mark your back plate so you can see that it is rotating. I always try to use enough pressure to just keep the pad doing a full rotation about every second with my initial passes, after you see the polish start to dust and turn clear it`s fully broken down and you can back off the pressure and make 1 or 2 more cross hatch patterned with very light pressure(much faster rotation). When using finishing polish on foam I like to keep constant pressure through the polishing cycle. Maybe just personal preference. Hope this helps!
  7. #7
    GoFast908Z's Avatar
    Join Date
    Dec 2009
    Posts
    1,056
    Post Thanks / Like
    Agree with Joe.... Lots of Porsches out here and their paint is great to work on, and its on the softer side. Menz IP is outdated severely. D300 and Menz 203 is a solid 80-90% correction on Porsche paint.
    Jeff
    Immaculate Reflections Detailing
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Arctic Silver Porsche 993 C4S
    By countrysquire in forum Click & Brag -The Detailers Showcase
    Last Post: 09-26-2011, 12:41 PM
  2. 2007 Arctic Silver Lotus Exige S
    By Rob Tomlin in forum Click & Brag -The Detailers Showcase
    Last Post: 09-24-2008, 09:23 AM
  3. Black BMW 550i System One and Silver 540i 3M
    By imported_Totoland Mach in forum Click & Brag -The Detailers Showcase
    Last Post: 05-13-2008, 06:18 PM
  4. What zaino product for arctic white paint
    By Crazy3rdgen in forum Car Detailing Product Discussion
    Last Post: 07-25-2006, 04:00 PM
  5. SMALL PICTURES!2nd try! after pics 98 Arctic silver BMW
    By Balucanb in forum Auto Detailing 101
    Last Post: 09-02-2003, 07:17 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
