Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: P21S Use
  1. #1
    Join Date
    Sep 2001
    Location
    northern new jersey
    Posts
    106
    Post Thanks / Like
    i was having some trouble getting all of my AIO off without leaving some `streaking` and some residue, so i put some meguiars quick detail spray (NOT FI and NOT quick wax) on the car or MT, and it came off easily.
    but i`m confused and many have opinions on what`s good and bad in this process....
    can i safely put on a SG layer over my AIO that has been wiped with the meguiars Quick Detail?
    if not, how should i prep for SG?
    thanks!
    ---roadk
    Clean 2013 X1
  2. #2
    Join Date
    Mar 2009
    Posts
    1,538
    Post Thanks / Like
    For a safe buffing helper, try a quick spritz of distilled water on your MT. Also, apply less product next time. I`m not quite sure about the QD...how long did you let it sit? I believe a lot of the cheaper QD`s have a lot of IPA (isopropyl alcohol), which you can use to remove Klasse if you decide to start over.
    If you really want assurance, either apply another coat of AIO or wash the car (rather AIO). Neither can hurt you. I`d recommend the extra coat of AIO though.
  3. #3
    Join Date
    Mar 2009
    Posts
    313
    Post Thanks / Like
    i also experience better results over all with the QD over FI. i think this is mainly due to the fact that the QD has silicones and FI doesnt. im not sure if its the same for klasse but for zaino the zilicone isnt good for layering zaino on. kinda like oil, so i would use dawn if i were to use QD. maybe u should dawn wash ur car a little before starting enw layers of klasse
  4. #4
    Join Date
    Jun 2009
    Posts
    547
    Post Thanks / Like
    P21S Use
    I got my bottle of P21S a couple of weeks ago and have a chance to use it a couple of times, once on that Buick with the chrome rims and once on my S60R with the painted rims. It worked AWESOME on both and probably could have let it dwell a little longer on each, but was still amazed with the result, especially on the wrecked Buick`s (it`s not hard to clean mine as I have multiple layers of sealant on them).
    Anyway, my question is, how many cars can you do with a bottle of that stuff? I transferred the 32 oz to my Griots Spray Bottle and don`t feel like I`m over doing it when spraying it on, but it looks like it will be going SUPER fast and probably 1/4 of the way gone already, maybe not quite, but close.
    Am I doing it right? Should I use a different sprayer or application method? I haven`t even done my wife`s XC90 yet and it has big ol 19" rims/tires on it, I imagine it`ll take quite a bit.
    Thanks in advance.
    2012 Acura TSX Special Edition, Crystal Black Pearl
    2007 Volvo XC90 Sport, Passion Red
  5. #5
    Join Date
    Jan 2002
    Location
    Atlanta, GA
    Posts
    8,402
    Post Thanks / Like
    If you are using the gel, you can spray it right onto a EZ detail Brush for the barrels of the wheels.
    Bryan Burnworth - Atlanta Car Detailing - Peachstate Detail LLC
    Selected as one of the top nine detailers in the US by Autoweek
    Published in the 356 Registry
    The only exclusive Opti-Coat Pro specialist in Atlanta
    All PPF work done by the best in Atlanta Derek Johnson of Atlanta Protective Films
    Follow Peachstate Detail LLC on Facebook here.
  6. #6
    Join Date
    Jun 2009
    Posts
    547
    Post Thanks / Like
    Quote Originally Posted by gmblack3 View Post
    I guess I was under the impression that I needed it to dwell a while BEFORE I went to scrubbing it. If not, this makes a lot of sense. I have the Griot`s Wheel Brushes, which work awesome for most wheels, so maybe I`ll have to go that route. It will definitely save quite a bit of product.
  7. #7
    Join Date
    Jan 2002
    Location
    Atlanta, GA
    Posts
    8,402
    Post Thanks / Like
    Quote Originally Posted by Husker Z View Post
    Depends on how dirty they are to start with. If you have OEM pads on the volvo, they might need some dwell time if its been a while since your last cleaning. If you have the wheels sealed up, they should not require that much dwell time.
  8. #8
    Join Date
    Jun 2009
    Posts
    547
    Post Thanks / Like
    Makes perfect sense, thanks. Yes, the Volvo pads are crazy dusty, but I do have the wheels all sealed up, which helps a lot. Thanks again, I love the P21S, but I was afraid I was going to be buying it in bulk if I kept using this much of it on each car! ut:
  9. #9
    Join Date
    Sep 2009
    Posts
    505
    Post Thanks / Like
    Yeah I did 4 cars and the bottle was gone. I sprayed enough to coat the wheels. Works good like you said though. I have to buy the bulk size now, but it is the best wheel cleaner I`ve used.
  10. #10
    Join Date
    Jun 2009
    Posts
    547
    Post Thanks / Like
    Quote Originally Posted by Indy YZF View Post
    Glad I`m not the only one! The Buick took most of it, but you should have seen the driveway after dwelling on it for a while, crap was just running off of the tires/wheels.
  11. #11
    Join Date
    Mar 2009
    Posts
    742
    Post Thanks / Like
    then i`m glad i got the 32oz to begin with...
  12. #12
    Join Date
    Jun 2009
    Posts
    547
    Post Thanks / Like
    Quote Originally Posted by glfahlc View Post
    Yeah, me too, for sure.
  13. #13
    bmw5541's Avatar
    Join Date
    Sep 2009
    Location
    Flanders, NJ
    Posts
    3,124
    Post Thanks / Like
    Husker,
    The P21S Gel is truly a great product for sure. It does go fast however. If your wheels are very dirty, you will deffinitely need to let them dwel for a while. The directions on the bottle say that you can let them dwel for up to two hours. Once they are clean, make sure to seal the wheels (I really like Wheel Wax). This will make it much easier to clean the wheels the next time you wash the car. You shouldn`t have to use the gel every time you wash the car. Once sealed, you should just use car shampoo and a brush and they will come nice and clean.
    Barry Schultz
    Detailed Elegance
  14. #14
    Join Date
    Jun 2009
    Posts
    547
    Post Thanks / Like
    Quote Originally Posted by bmw5541 View Post
    Husker,
    Yeah, I probably didn`t need to use it on my car, I put wheel wax on it a while back, and a month or so after that put a coat of BFWD on it followed by Midnight Sun. They are pretty easy to clean. I just had this new bottle of stuff that I felt needed used!!
    Thanks! I`m betting your Bimmer`s brakes are as dusty as mine.
  15. #15
    bmw5541's Avatar
    Join Date
    Sep 2009
    Location
    Flanders, NJ
    Posts
    3,124
    Post Thanks / Like
    You aint just whistlin` dixie! I am so obsessed with keeping them clean, and it is so difficult. I am at the point now, that I am wipping them down pretty much every day. Fortunately, the Wheel Wax, does a great job, so all I have to do is use an old MF or cotton towel and it comes clean. My hands, on the other hand are a whole other story. I really need to start wearing gloves:banghead:
    Barry Schultz
    Detailed Elegance
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. P21S wax question for P21S experts
    By yan_750i in forum Car Detailing
    Last Post: 04-13-2008, 02:22 AM
  2. Dilution questions; P21S Gel Wheel Cleaner and P21s TAW
    By BMW335i in forum Car Detailing Product Discussion
    Last Post: 08-23-2007, 01:23 PM
  3. Klasse topped with P21S or just P21S?
    By imported_Goose in forum Car Detailing
    Last Post: 02-28-2003, 01:14 PM
  4. Sealants vs. P21S`s GEPC + P21S
    By schoi in forum Car Detailing
    Last Post: 02-19-2003, 10:49 PM
  5. P21S vs P21s over Souveran on black?
    By garageboy in forum Car Detailing
    Last Post: 02-15-2003, 03:02 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
