I`ve read that WB should be diluted 4:1 and it`s still pretty strong at that rate. At 4:1, how does it compare to Hot Rims All Wheel Cleaner at that dilution rate?
I like Hot Rims wheel cleaner but it is stronger than what I need on a regular basis since I now wash the wheels on a fairly regular basis. Heck, most of the time, car soap and wash sponge are more than enough. However, I like the wheel cleaner spray because it makes it so much faster when you`re in a rush.
I`m also asking because I am looking for a low cost wheel cleaner solution that can also be used regularly on clear coated OEM wheels.
Can I dilute WB at 6:1 (or even 8:1) to reduce the harshness of the cleaner but also still have a quality cleaner for light brake dust buildup?
Thanks in advance.
Bookmarks
