Hello, gentleman, it`s time for me to ask for a little help. I`m going to take my detailing to (hopefully) the next level this weekend and try to really perfect some basic paint damage on my 98 Arctic Silver M3/4. I`ve done a couple details with my PC 7424, one on a pretty old and abused red pearl 300ZX and another on my girlfriend`s abused 2002 Audi A4. I can`t really say that I was happy with the results either time. The Z was left with a lot of scratches and I never really got the pearl to pop. The A4 was pretty much untreated the last 3 years (my gf has gotten an earful for this already) and much of the paint was still covered in water spots and some very rough areas. My old process-
PC Orbital and LC 6" pads - wool,yellow and white.
-Dawn wash x2
-Zaino clay
-Zaino Wash
-Menzerna IP via wool & yellow pads - speed 6 for much of it - spray with 50/50 IPA/water solution
-Menzera FPII via white pad - lower speeds - wipe with MF only
-Zaino Z2 (now pro) x3
Now, admitted, the Z was in pretty bad shape and no orbital could solve most of the problems - but it looked good for a 12 year old car. The A4 is not up to my standards. So now I`ve picked up an Edge2000 8" pad set and some SSR3 in preparation for my Bimmer detail this weekend. The paint has some usual swirls, slight holograming and a couple scratches and some blemishes which may be clear coat overspray.
The plan:
-Remove body trim, mask all plastic (duh)
-Dawn x2
-Zaino Clay
-Wash (Zaino wash?)
-Start with Edge Green and IP - step up to Edge Yellow or Black if needed. Wipe with IPA/Water and MF
-Edge Blue (or White?) and FPII - wipe with MF (or IPA too?)
-**Wash???**
-Z-16 before and in between 3 layers of Z5
-Z-16 before and in between 3 layers of Z2-Pro (day 2)
-Maybe Megs #16 as a topper
So the plan isn`t that different, unless you`d advise I pick up a cheap rotary, maybe the Vector Waxxpro (Pep Boys) or the Chicago Electric (Harbor Freight). I was thinking I`d need a circular in order to address the truly tough spots. This is also why I picked up the SSR3 - just in case I needed more cut.
My main concerns are:
-Do I really need a rotary to address some common swirls, and do I need it for some more defined defects like the scratches and blemishes? Can an Orbital, some more abbrasive pads and SSR3 provide me with enough cut to address my needs?
-Should I wash the car after compunding/polishing or is an MF wipedown good enough?
-Is there anything I can do to better prep the paint in between the FPII and the Zaino? No glaze I have heard of seems to allow the Zaino to bond.
-Will #16 do anything to enhance the shine/depth on a Zainoed silver car?
-If I have to clean the pads in the middle of a step, can they be used when damp?
-Can Zaino be applied by machine?
Sorry the long post, I`m just nervous about having everything I need before I get cracking on this in the morning.
I will post again when I retackle the A4, which I`m certain needs a rotary and some SSR3 to smooth out some fairly rough paint.
Thanks, guys!
Bookmarks
