I have a two year old Tundra, 20,000 miles, two salty winters-never had engine cleaned. My observations-
1. some grime, not too bad-
2.a lot of black tarry looking stuff, unevenly distributed, most noticeable on the painted metal frame parts. I suspect this is rustproofing overspray?(your thoughts?)
3. I read many articles, including DavidB`s and followed his instructions as best as I could- except I used Simple Green because I have a ton of it. I originally sprayed it diluted 3:1, and rinsed, and then full strength and rinsed
it got a lot of stuff loosened up, but not much that just rinsed away. It barely touched the overspray.
4. I have been making funny little brushes, by bending toothbrushes, and taping them to things like old cue-sticks. The SimpleGreen works pretty well if I can get a toothbrush on it, and then a rag.
5. As far as the overspray goes, the only thing that touches that is a solvent, I`ve been using 3m adhesive remover on the painted surface, doing my best to keep it off of any rubber, platic, or any engine parts at all. What a pain this has been.
i have more to do, but here is where I am headed, and would like some input-
1.I don`t really care what the engine looks like from the bottom up. If that`s my rustproofing overspray, I`d just as soon leave that undisturbed down there.
2.After I get it cleaned up to my satisfaction if figure I need to protect the engine with something. I have read that 303 protectant looks good and performs well. any thoughts on this?(I have some 303 already)
3. I need to protect the paint that I`ve wiped with the solvent. Reaching it with a wax or sealant (Zaino`s going on the outside) will be a major PITA, if not an impossibility.
4. overall, I want to make sure that in my effort to make the engine compartment look cleaner, i don`t deprive it of any protection against degradation.
Advice please- Thanks in advance
Bookmarks
