Page 1 of 3 123 LastLast
Results 1 to 15 of 43
  1. #1
    jrock645's Avatar
    Join Date
    Jul 2015
    Location
    Chicago, IL
    Posts
    2,068
    Post Thanks / Like
    Uh oh. How to remove Miyabi coat?
    So I applied Miyabi coat last weekend. Did the first coat Sunday afternoon, and it was super easy. Did 2-3panels at a time with no issues. Easiest wipe off I’ve ever seen on a coating. Did the 2nd coat the next day, and since the first was so easy, I did 3-4 panels at a time.
    Problem is, it was earlier in the day, the sun was higher and a bit brighter. Wipe off was impossible on the panels that were getting the most sun. So I have high spots on the hood, roof and trunk lid, and in the tops of the rear and front drivers side quarter panels.
    Yeah, dumb move on my part.
    I figured I could just polish this stuff off, like I’ve done with gloss coat. No such luck. Used the rotary withpolishing and cutting pads and 3D compound, even tried it with the compound and the Urofiber pads on the Rupes. This stuff won’t budge.
    So how do I get these high spots off?
    2018 Acura TLX ASpec
  2. #2
    Join Date
    Aug 2011
    Posts
    830
    Post Thanks / Like
    Re: Uh oh. How to remove Miyabi coat?
    If a rotary and compound wouldn`t take it off, I doubt if any chemical solvent will remove it. Hate to say it, but live with it or wet sand it off. IIRC, GTechniq has a coating that the only way to remove it, is to sand it off.
    Likes jrock645 liked this post
  3. #3
    Join Date
    Mar 2012
    Location
    Reisterstown Md.
    Posts
    3,075
    Post Thanks / Like
    Wipe it with 91 percent alcohol straight, then a microfiber pad and I use Griot’s fast correction cream, but a compound will remove it. Never had a problem getting it off. You can also call Todd and see what he says.
    Likes jrock645, BudgetPlan1 liked this post
  4. #4
    jrock645's Avatar
    Join Date
    Jul 2015
    Location
    Chicago, IL
    Posts
    2,068
    Post Thanks / Like
    Quote Originally Posted by Mike lambert View Post
    Thanks. Will try this tomorrow.
    By Todd, you mean Rupes Todd?
  5. #5
    Join Date
    Jul 2011
    Posts
    1,273
    Post Thanks / Like
    Nah. I think he means Todd C of Esoteric
  6. #6
    Join Date
    Mar 2012
    Location
    Reisterstown Md.
    Posts
    3,075
    Post Thanks / Like
    The distributor Mr. Cooperider.
  7. #7
    BudgetPlan1's Avatar
    Join Date
    Apr 2010
    Location
    NE Ohio
    Posts
    2,668
    Post Thanks / Like
    First time I used it, hadda redo a panel a week later. Menz 2400 w orange light cutting pad seemed to do it for me.
    Interesting...
  8. #8
    rlmccarty2000's Avatar
    Join Date
    Dec 2014
    Location
    Fitzgerald, GA, South East GA
    Posts
    4,498
    Post Thanks / Like
    Would it be easier to remove after the coating had fully hardened? I’ve removed CQuartz with Menz 3500. That Miyabi must be some tough stuff.
  9. #9
    jrock645's Avatar
    Join Date
    Jul 2015
    Location
    Chicago, IL
    Posts
    2,068
    Post Thanks / Like
    Quote Originally Posted by rlmccarty2000 View Post
    Its been on for a week.
    And yeah... I figured most coatings would come off with just some normal polishing. I was not expecting it to be this difficult. Hit it with 205 first, nothing. Then 3D compound on the rotary, nothing. Then 3d compound again with urofiber on the Rupes. Still there. I can’t even believe it.
  10. #10
    Join Date
    Dec 2014
    Location
    Posts
    4,498
    Post Thanks / Like
    Quote Originally Posted by jrock645 View Post
    I had heard of some coatings needing to be wetsanded off but I thought it was bs. Now I’m not so sure. I was thinking of using Miyabii the future, I might need to stick with something less permanent. Always learning.
  11. #11
    Join Date
    Apr 2010
    Location
    NE Ohio
    Posts
    2,668
    Post Thanks / Like
    I`d guess that you may have a pretty thick layer (cured) on there (relative to an applied/buffed) panel, perhaps? If so...er, uh...I got nuthin. As mentioned, I`d call Esoteric and see what they have to say or try something heavier than HD Compound. Maybe something like D300 on microfiber?
    Likes SWETM liked this post
  12. #12
    Join Date
    Dec 2014
    Location
    Posts
    4,498
    Post Thanks / Like
    Quote Originally Posted by BudgetPlan1 View Post
    Menzerma has a new FG 300 compound that I bought but have not tried. FG 400 has always been sufficient. FG 300 has the most cut that I know of without wetsanding. After using 3M 3000 grit pads on headlights I would consider using them to remove a coating safely, but I hope you do not have to wet sand that coating off.
    Likes BudgetPlan1, SWETM liked this post
  13. #13
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    86,994
    Post Thanks / Like
    jrock645- Oh, man sorry to hear that my worst fears about coatings have been visited upon you..sounds simply awful
  14. #14
    Rasky's Auto Detailing RaskyR1's Avatar
    Join Date
    Mar 2009
    Location
    Eden Prairie, MN
    Posts
    5,011
    Post Thanks / Like
    Removing a high spot, especially an intentional one, is totally different then removing a properly leveled coating. In those stories of needing to wet sand it off the product was applied and never leveled, which is a huge difference. I`ve never had a coating the was properly applied/leveled that couldn`t be compounded off.
    Likes BudgetPlan1 liked this post
  15. #15
    jrock645's Avatar
    Join Date
    Jul 2015
    Location
    Chicago, IL
    Posts
    2,068
    Post Thanks / Like
    Ok, spent a couple hours on it with limited progress.
    Did the 91% IPA wipedown. Was able to remove almost all of it from the hood. There’s a couple small high spots left, but they’re equivalent to smudges like a thumbprint. 2or 3that I’ve seen. I can live with that. Reapplied Miyabi coat here and the hood looks pretty good.
    Did not have the same luck with the rear quarter panel or trunk lid. Did the rear quarter panel 3 times. First with compound and rotary(combo of HD cut and 3D 501), then twice with Rupes and microfiber cutting pad with same compound combo. I may have lessened a little of it, but it’s mostly still there.
    At this point I stopped out of frustration. Guess I’ll just live with it. Hopefully what I did will at least weaken the coating a bit, to where it won’t last too long.
    Likes SWETM, BudgetPlan1, rlmccarty2000 liked this post
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Kamikaze Miyabi / ISM
    By BudgetPlan1 in forum Car Detailing Product Discussion
    Last Post: 05-22-2020, 07:56 AM
  2. How Do I Remove BF Crystal Coat?
    By ebferro in forum BlackFireWax.com
    Last Post: 05-18-2017, 11:34 PM
  3. Has anyone tried BOTH Kamikaze Miyabi and Polish Angel Cosmic?
    By cobrar97 in forum Car Detailing Product Discussion
    Last Post: 05-10-2016, 12:36 PM
  4. When applying a second coat why remove the first coat ?
    By DM101 in forum Car Detailing Product Discussion
    Last Post: 06-19-2009, 04:28 PM
  5. quickest way to remove clear coat
    By speed_d3mon in forum Car Detailing
    Last Post: 04-19-2003, 11:34 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
