I`ve been noticing that my mytee is sometimes letting out cool water, although it can be very hot at times... I dont think this is normal. Anyone else experienced this before? I`m still under the one year warranty. This is my third replacement...
it should only be cool at first keep running the water through and once its hot it should stay hot if you turn it off or unplug it it`ll have to warm up again
the thing is it doesn`t stay hot although I leave it on...
i just wanted to ask if this was normal before I called them.
mine sometimes will get cooler after I use it for a little while...but it still stays hot...just not as hot as it was when I first starting using it.
It is not worth doing unless you do it right
It should be able to keep up.
Bryan Burnworth - Atlanta Car Detailing - Peachstate Detail LLC
Selected as one of the top nine detailers in the US by Autoweek
Published in the 356 Registry
The only exclusive Opti-Coat Pro specialist in Atlanta
All PPF work done by the best in Atlanta Derek Johnson of Atlanta Protective Films
Follow Peachstate Detail LLC on Facebook here.
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
