any good 'value' orbital buffers?
I know most here use the pro stuff, PC, Dewalt, GEM, etc.
But are there any decent orbitals out there that strike you as a good value for a beginner, occasional user? (Harbor Freight,Northern, Sears?)
I also have an air compressor. Are there some air powered orbitals that might be priced better with good quality.
If this is a `get what you pay for` type of product, let me know and I`ll start saving, looking at ebay, or closeouts.
thanks much.
PS just used Meg`s consumer 3 step product line (deep crystal). Turned or ok. Better than before which was the goal. But man am I soar.
Thanks much, this stuff is sort of fun.
Real question is do I need it
After spending days sifting through the posts on this board,
I`ve decided to follow the AIO/UPP routine that so many find success with. It seems that these are both so easy to do by hand that a power tool isn`t necessary
The real issue is swirl removal on a car that needs it. It seems that a power tool is required if one doesn`t have the time or arm strength to do it all day by hand.
But once you remove the swirls, and you take care of it and don`t reintroduce the swirls, than is a power tool really necessary?
On the flip side as well, I have an older car that will be donated to charity soon. 91 Taurus. Blue paint that has oxidexed to a white haze. Now in order to remove the oxidation, an orbital won`t produce the heat needed to do any good, I think. So now I `d need a rotary. But once done with it, how often would I use it
Thanks all for your time.
