advice repairing deeper scratches?
Hello all:
I need help with a couple scratches that are driving me nuts - like the way little imperfections in your paint usually do.... :mad:
I have a couple deeper ones in my paint that lighter compounding won`t touch (so far I have used some SMR`s and a PC w/ a white polishing pad). They do not go through to the metal or even the primer (one of them is on the side of the plastic taillight housing). I have a single stage black enamel paint. I am wondering if I should use a harsher compound/pad combo and try to buff it out with my PC, or if wet sanding these areas first with 1500 or 2000 grit paper will level / knock down the edges of the scratch enough to compound it in an effort to get it out, or at least make it much less noticeable? Is there any difference in which approach I use, or is there an advantage of one over the other?
ANY recommendations or advice from anyone experienced with this procedure?
Thanks alot!
Brian
