tar n bugs n scuff marks ....ohhh my
i just started detailing this year with the weather n all here in philly ive been doin it 3 months on a dailly basis 7 days a week
i started with 3 m bug n tar and 3 m compund liquid one day i grabbed the compound and threw the bug stuff away one bottle is all i need not two also im practically finding cars that have never been taken care of so this tar has been on fer awhile i dont use machines and it melts like butter i dont understand the problem with wax removal though yall seem concerned.....i add that to the sales pitch
Sir i can get it off see this spot ? ....gone.....but !!!!! ill have to rewax because although it is safe for ure clearcoat it completely removes the wax !!!
Tire rubbers and removing spots
An update for you guys removing tire rubber:
I get two kinds of rubber on my finish - one, race compound (race tires), and two, street compounds. I found there are two approaches best to use for removal.
If you get tire rubber buildup from the street, it tends to go on thicker. I had over 1/32" of buildup on the rear quarter panels by the rear tire edge. This rubber tends to melt at higher temperatures and buildups need to be dissolved, so the kerosene works best. For thicker areas I used a fingernail and helped scrape it off.
Race rubber is a different compound and can be treated differently. I`ve never gotten huge thick buildups but very thin streaks of rubber on the finish. After a track day, a liberal amount of soapy water and fine (blue) clay removes the streaks and spots fine without needing to resort to the kerosene.
