well after all the hype on heated portable extractors i decided to get a Durrmaid hot mini extractor from Detail King (seen at bottom of page).
Specs: The perfect mini extractor for the mobile detailer or express detailer. Unit includes a 1600 watt heating system; heats water to 200 degrees in 8 minutes, 60 PSI pump, 102" water lift, 16`non colapsable hose with 3" stainless tool as shown, 1.5 gallon solution tank, 2 gallon recovery tank,2" swivel casters, wide wheel base prevents tip-overs, easy to fill and empty, pigtail cord, easy to carry and store, weighs only 18 pounds. Can`t go wrong with this unit. Dimensions: 18"L x 13"W x 17"H. NOTE: IF USING 14 GAUGE EXTENTION CORD IT CAN NOT BE LONGER THAN 25`. IF USING 12 GAUGE 50`IS OK.
So i waited about 2 weeks for Delivery. i received it in a box with no styrofoam just a piece on the bottom everything else was loose, No recepit. Ive used this machine about 3 times since then.
I really like the portability of this machine, its real light weight. Ive used hot extractors before and this machine says it has 102 water lift but i think my shop vac has more suction than this does. Also this machine is too loud, its louder than a pc & a rotory which gets kinda annoying.
What i didnt like was when i connected all the hoses where inlet goes into the machine for the water it dripps water from that connection hose. the water gets very hot but when its sprays its still cold. Ive sat down and let the spray go on til the hot water came out and it only came out luke warm. this is not what i expect from a $700 machine.
Ive had to call DetailKing several times about the Suction/Lift i was told to make sure all the caps where the water went were closed pretty tight and they were. Then i was told to make sure the hose was connected to the machine correctly and it was.
My second call was regarding the dripping water. The last thing i need is to have the water dripping and moving towards the cord :scared. I was then told to make sure all the fittings on the inlet and outlet for the water were not loose. Checkd them and they were fine.
My last and final call was regarding the Temperature of the water. In the solution tank where i filled up the water you can feel the cap and it was pretty hot. The water does not come out hot only warm. I referred to my manual which said if the water wasnt hot to check if the water level it not too low, because if it is then the heater pump will turn off. But at this time the water level was at its max. I was then told to spray out all the existing water from the hose and it would be fine. did that and its still warm. I knew people had doubts about this machine but i never saw anyone on any of the boards who actually had one. I guess i was the lab rat for this one.
After a month or so regarding these issues i called Detailking back and i asked if there was any kind of money back guarantee (which i was told there was) but am now being told no, its probably a user problem. I dont intend on doing business with Detail king again.
I called Anthony Orosco to see if hed like to test this machine out to see if its a user problem. Hopefully he can do a write up and we can compare issues..
thanks
