Product Catagory Definitions?
I have been thinking about it ...and trying to figure out what the differnt terms mean.. Perhaps someone can help me out on this one!
1. Compound - Typicly I would say this would be anything that could be considered an abrasive (Rubbing combound, SSR line ect)
Here is where I get confused
2. Polish
3. Glazes
4. Sealents
5. Waxes/ the different types of waxes (ie. Carnuba vs polymer)and what are the features and benifits of these?
Is there anything missing in there?
Another question is in what order do you typicly want to apply to the car? can you put a wax under a sealent or above a sealent? can you top a wax w/ a glaze or do you do it the other way around?
Last question I have is about the differnt types of pads...(i have these pads (http://www.properautocare.com/porcabac.html im not sure they are the greatest but they were afordable so that was what I bought) But back to the question ...What makes a each pad what it is (ie. cutting pad ,polishing pad, finishing pad) is it the firmness of it.
I thought it would be better to know this info that way I would be better utilizing the products I have in my arsinal and be using the proper aplication methods!
Re: Product Catagory Definitions?
A compound is classified as a highly abrasive material to rectify MAJOR paint defects - generally referred to as cutting compounds.Example: meguiars Diamond Cut Compound
2. Polish These are abrasive compounds ranging from medium to slight abrsiveness They correct not so severe paint defects *generally* - there are exceptions and a rotary is a powerful tool that can work wonders with less aggressive polishes to correct some pretty awful paint defects. Examples of polishes are: the SSR series, Menzerna twins, DACP, #80, 3M SMR etc
3. Glazes A glaze can be abrasive or non-abrasive in nature. Designed to primarily add oils to the paint work to give a wet look finish, or it can leave the paint cleaned and ready forany LSP. Example: Megs #7, Vanilla Moose, Klasse AIO
4. Sealents These are chemical barriers added to the paint, be they polymer or acrylic. Generally they are a long lasting paint protection. In most cases they give a sterile high shine look due to the lack of oils present. Examples: Klasse SG, Wolfgang, NXT, EX-P, Zaino, Blackfire
5. Waxes/ the different types of waxes (ie. Carnuba vs polymer)and what are the features and benifits of these? Wax is generally carnauba based ( oil extract ) and are in most cases not as lkong lasting as a sealant. Polymer compounds ( such as teflon ) are added tot he wax to improve the slickness but has no real advantage of improved durability. Examples: Nattys, Souveran, P21S, #26, 3M showcar wax, blitz
Another question is in what order do you typicly want to apply to the car? can you put a wax under a sealent or above a sealent? can you top a wax w/ a glaze or do you do it the other way around? No, you would add a wax on top of a sealant, the oils in the wax tend to interfere with the sealant "bonding" to the paintwork. The glaze on its own is not very durable and is generally topped with a wax. There are certain sealants ( like PB EX-P and WG ) that can be used over a glaze despite the oils present, but the general rule is no oils under a sealant - keep reading up and you will get the grift on which ones can and cant ;)
Last question I have is about the differnt types of pads...(i have these pads (http://www.properautocare.com/porcabac.html im not sure they are the greatest but they were afordable so that was what I bought) But back to the question ...What makes a each pad what it is (ie. cutting pad ,polishing pad, finishing pad) is it the firmness of it. Nothing wrong with that pad selection, and yes you are right the density ( or firmness ) of the pad determines the "bite".
