I have done a search and haven`t found anything on this subject. I was messing around with some products, one side I was applying DACP with my PC and the other side I was using a rotory. By the way DACP is a pretty good product. Anyway when I was using the rotory I kept getting rotory hop. Method of application: I primed the pad by spraying some clay lubricant and then putting an X pattern of product on the pad, started off slow and worked the product in. As I was working in the product the pad seemed like it was grabbing and started to hop. I think I am either not working it in enough or I am working it too much. When using the rotory when do you know that enough is enough? Some people tell me that when you can barley see the product you should stop. I followed that rule and the pad kept hopping. I am not getting a smooth flow with the rotory that I should.
