Re: Waxes and more Waxes!
You can`t go wrong with either one of those. The 3 oz size will last you awhile. Another wax that fly`s under the radar is DP max wax. To be honest you can`t go wrong with any of the house brands.
bfms is my favorite especially over bfwd. it`s still on sale too! Blackfire Midnight Sun Batch #25 Carnauba Paste
Tough choice. Since your daily driver takes a lot of abuse, I`d go with BlackICE. If you were in friendlier weather conditions, then I`d go with BFMS.
Quote:
Originally Posted by
The Guz
+1 on DP Max Wax.
tropicsteve
+1. You only need the smaller one as it will last a long time. applies very thin and you don`t wait for hazing. this will give you the warm look you are trying to achieve. If you have harsh driving conditions, I would reapply every 30 days. Maintain in between with MS Instant Detailer after 2BM wash (as drying aide while paint is still minimally wet after a sheeting rinse) and Polymer Spray after rinseless washes (on dry paint).
You really shouldn`t need to apply CS more than once every 6 months. Use it as your topper after BFWD (wait 24 hours after BFWD, then 2 coats of CS 1 hour apart). If you top that with MS and maintain after washes as mentioned above, you shouldn`t need to reapply CS until your next full detail.
Thanks guys!
Looks like I`ll stick to BFBI and BFMS. I`ll hold off on the BFMS for now, as I`ll survive with poly/CS until next summer season.. I think.
I tend to use CS for the windows right now until I get my hands on some Gtechniq G5, and it works great. I find it diminishes to a noticeable level (water flies off at around 55km/h fresh, after about 2 weeks it starts to work around 65+) that I`ll need to re-apply. Regular wash/top off right now holds with poly spray, and I`ll keep that going until winter.
I`ll have to pick up some rinseless/waterless washes next year as I`m finding the full shampoo loads are a bit much for summer dust.
Maybe I`ll start a sort of long term winter torture test for BFBI when I get it...
Vega@Autopia
+1 on DP Max Wax.
Vega (or anyone who`s used both) .... I live in the Northeast and I`m looking for a Carnauba wax as well. It needs to be effective on dark (BMW Space Gray Metallic) AND light colored paints since I own both.
Why the BlackICE over Midnight Sun?
SON1C Wax Phoenix is another wax in the mix.
Is SON1C or DP Max Wax a better choice if it`s not intended for winter protection?
SGM2008
Most pure carnauba waxes on average last 3-8 weeks. BlackICE is a hybrid wax with added polymers (a blend of natural and synthetic wax). So it`s more durable than a pure carnauba wax, lasting up to 20 weeks. Although it was designed for black cars, it looks great on any color. There are a lot of examples and reviews online on different colors, including white. For best results, properly prep the surface first, then apply a sealant first. BLACKFIRE Wet Diamond All Finish Paint Protection would be perfect. Allow it to fully cure for 12 hours before topping the sealant with BlackICE.
To prep the surface, first wash the car. Then perform the "baggie test" to determine if you need to clay or not. If you don`t need to clay, use a non abrasive polish or chemical cleaner like BLACKFIRE Gloss Enhancing Polish to clean the paint and prepare it for the sealant and wax combo.
SGM2008
If it`s not intended for winter protection, both are great choices. There is a considerable price gap between the two. SON1C wax Pheonix is $85.00 for 5.07 oz while DP Max Wax is 39.99 for 8 oz. I`d consider DP Max Wax to be more of a pure "beauty" wax, while SON1C wax is more durable and look shinier. I would expect SON1C Wax to last longer on the paint. The fact that DP Max Wax can compete with a wax that costs more than three times its cost per ounce, ($16.77 per oz v.s. $5.00 per oz) is an example of what we mean when we say it "flies under the radar".
Vega@Autopia
If it`s
I`ve already clayed the car and I`m polishing with SF4000. Any wax I choose would not be intended for winter protection, but that doesn`t eliminate any of the waxes I`ve asked about from consideration. I used Sonax Polymer Net Shield for winter protection last year and in my opinion, the durability is awesome.
For the warm weather months, I`ve been using Einszett Glanz and Prima Hydro Max mostly because of their ease of application and removal. I have a BFWD sample, but I`ve never applied it to the entire car.
My concern with the higher priced waxes is not so much the initial cost. It’s more of what do I do with a half used pot of wax when the “next great wax” comes out. It’s a lot easier to give away or not use a $20 wax as opposed to an $85 dollar wax.
Thanks for the explanation between the waxes!
silverfox
We could feed the world (or pay for the next coming war) if we cashed in on all the unused car wax sitting on dusty shelves. Drug addicts and neocons have nothing on waxaholics
I resemble that comment
:mad:
SGM2008
Amen !!!! :yourrock
Ronkh
:mad:
Me too. I too have a problem. :)
