BLACKFIRE Interior Protectant vs. Detailers Pro Series Interior Surface Protectant
For this comparison review I`m going to test BLACKFIRE Interior Protectant vs Detailer`s Pro Series Interior Surface Protectant on my 1998 Honda Civic EX Coupe`s grey interior previously protected by 303 Aerospace Protectant.
Prior to applying these two products, I cleaned the entire interior with Detailer`s Pro Series Total Interior Cleaner:
http://www.autogeekonline.net/forum/...pictureid=4408
(http://www.autopiaforums.com/forums/...omparison.html)
From Autopia`s product page for BLACKFIRE Interior Protectant:
"BLACKFIRE Interior Protectant is the only product you need to maintain the look and feel of leather and soft vinyl upholstery. This 100% water based protectant uses micro-engineered polymers that are readily accepted by leather and soft vinyl. BLACKFIRE Interior Protectant contains no oils, silicones, or petroleum distillates. It leaves a deep, satin, natural-looking finish on interior auto surfaces. This unique protectant is perfectly pH-balanced (7) to match the pH requirements of leather. After treatment, a micro-fine moisture barrier remains on the surface to resist perspiration stains and help retard UV-induced fading."
For applying BF IP I sprayed 1 shot on a round microfiber applicator pad. BF IP bottle was given a quick shake before use:
http://www.autogeekonline.net/forum/...pictureid=4413
When sprayed BF IP has a milky consistency that is quickly absorbed by the mf applicator pad.
From Autopia`s product page for Detailer’s Pro Series Interior Surface Protectant:
“Detailer’s Pro Series Interior Surface Protectant is a multi-surface shield for your vehicle’s interior. It maintains the supple, fresh texture of vinyl, leather, plastic, and rubber while blocking out harmful UV rays. Treated surfaces resist fading, drying, and cracking so your interior maintains a fresh new look. Detailer’s Pro Series Interior Surface Protectant keeps interior surfaces looking like new for the life of your vehicle.”
For applying DP ISP I sprayed 1 shot on the reverse side of a the same round microfiber applicator pad. DP ISP bottle was also given a quick shake before use:
http://www.autogeekonline.net/forum/...pictureid=4412
When sprayed DP ISP has a grey-blue gel consistency that is slowly absorbed by the mf applicator pad.
Side by side results: Both products were applied to an equal size section on the passengers side dashboard:
http://www.autogeekonline.net/forum/...pictureid=4403
http://www.autogeekonline.net/forum/...pictureid=4407
(A little blurry, sorry)
I then waited a 5 minutes before giving them a quick buff to knock down any high spots and removed the blue tape to expose my clean control surface:
http://www.autogeekonline.net/forum/...pictureid=4410
http://www.autogeekonline.net/forum/...pictureid=4409
(With iPhone flash)
Even though the results may appear similar, BLACKFIRE Interior Protectant left more of a satin finish then Detailer’s Pro Series Interior Surface Protectant. To make sure this difference in sheen wasn`t being caused by my light source I adjusted my work light so it was directly over the center of my control area.
Smell: BF IP has a very neutral smell. On the other hand DP ISP has a subtle hint of banana but you really have to give the bottle a good sniff to notice it. I`ve read the banana odor in earlier versions of DP ISP was significantly stronger and hard to miss. Thankfully this doesn`t seem to be the case any longer.
Cost: Of the size options available, 128oz is the only one both products come in so I’ll base my cost break down on 128oz thus making price 100% comparable:
- BF IP $.70 per oz/ 89.99 per 128oz bottle
- DP ISP $.47 per oz/ $59.99 per 128oz bottle
At the largest and most economical size option BF IP is 40% more expensive per oz then DP ISP.
Conclusion: Both are excellent products, contain no offensive odors, can be used on all types of interior and exterior surfaces, are silicone free, and have UV protection from the Sun`s damaging effects. DP ISP however is quite a bit cheaper then BF and personally I prefer the finish DP ISP leaves behind more than BF IP.
Additional observations: Interestingly I noticed BF IP dries much faster than DP ISP. While comparing the two products in my small test area, BF IP was 80% dry to the touch after 5 minutes where DP ISP wasn`t at all dry and did require a quick buffing. This factor may be worth considering if you’re short on time when detailing your vehicle`s interior.
After removing my test area of both products I decided to apply BF IP to the whole dashboard, center console and door cards. Since this the very first time I`ve used BF IP I want to see how it holds up over time. I’ll be sure to update this tread with any observations I have.
Hope this review was helpful!
In addition, my prior review comparing DP ISP to 303 can be found here:
Re: BLACKFIRE Interior Protectant vs. Detailer's Pro Series Interior Surface Protectant
Nice review! I would suggest taking pictures without using the flash off angle. You will see a more realistic view and most contrast between the samples,
Great review! Thanks for taking the time to check things out and post em up
Thanks for the review! I really like Bf ip it is my go to protectant. It`s easy to use, and fits most of my customers needs in appearance, and protection.
Nice review. BF interior protectant is one of my favs.
Quote:
Originally Posted by
Bunky
Thanks! Interestingly the only way I could show the difference in the two products was shooting head on vs from an angle.
Docpeanut
Thanks! Hope I provided some helpful information
Klock
Awesome! Happy to hear
cleanmycorolla
Thanks!
Angus
You certainly did
