Re: Polishing Pad Priming!
Quote:
Originally Posted by
Rocket
Todd is there a specific reason to wait 3-5 minutes when priming the pad using the product? Just curious
Yes, great question. Waiting allows some of the solve to out gas, which leaves a higher concentration of abrasives. By blowing the pad out (or brushing) your remove any abrasives that have not fully bonded to the surface. The result is a more `hard barrier` of active abrasives.
You don`t have to wait, just like you don`t really even have to prime a pad, but you will generally achieve better results from doing both.
good info todd. i use the hybrid method most of the time. for glass i just use the product.
Very good info.
I`ve been priming the pad for years but I`ve not tried using the "pad conditioner" method.
I do, with certain polishes, spray a light mist of water on the pad surface before priming.
To me, this just gave a softer break-in & less saturation of product when priming the pad.
I typically use option 1 when using diminishing polishes but I will use a shot detailer as the pad conditioner. I tried the others but always seemed to over prime more.
Bunky
You should try the pad conditioner Al, I think you would really like it!
Great tips Todd!
I was just reading ur post on pad priming last night and u hv a new post today that summarise everything up!
It`s sort of surprising to see just how many don`t realize the importance of "correct" foam pad priming.
For the most part I use method 2. I like to ensure that the pores are evenly primed with the product I`ll be using then add a bit more to do the work...
Evenly Primed
http://i153.photobucket.com/albums/s...tailDay-04.jpg
Great thread Todd
Good info. By the way, has anyone told you that you sound a lot like Vin Diesel?
Instructions for some (water based) products say not to use pad conditioner. I guess because it could dilute the compound but it seems the small spritz of conditioner would not be enough to do that. Not sure.
Does the conditioner also make it easier to clean the pads afterwards (especially for the non-water-based products)?
thanks
LS6
thanks
BLACKFIRE Advanced Pad Conditioner is designed not to interfere with the polishing process (although some dilution is likely on the initial pass, although in our testing the benefit of priming the pad with the conditioner and allowing the polish to spread evenly across the surface of the pad far out weighs this).
That is if you loose 5% on the initial pass from dilution you gain 20% from the other benefits, thus resulting in a 15% to the positive.
However if the polish manufacturer specifically recommends against using a priming agent then I would follow the manufacturer recommendations.
01GreyStangGT
No, never! :rofl
