F10 brand new BMW deliver with etched water-spots damaged - restored and OPTI COAT protected
F10 BMW brand new delievered with waterspots damaged - restored and protected with opti coat by Detailiens
Getting new car always comes with bundle of joy & excitements
https://lh4.googleusercontent.com/-E...0/DSCF8745.JPG
My buddy, contacted me to protect his investment a couple of weeks ago prior collecting his brand new car, and we specifically mentioned not to be wash by road side car wash
on his way home driving thru some highway under construction and pilling
https://lh6.googleusercontent.com/-b...0/DSCF8522.JPG
splashes of `Wet` boring* spillage (drilling fluids) splattered the under wheel wells and lower side of the car
Quote:
drilling fluid systems usually consist components of a kerosene-like
petroleum base density compound.
so pls flush off instantly...to avoid hard to removed mud like stains....with Alien clean
https://lh5.googleusercontent.com/-C...0/DSCF8509.JPG
this is not an easy task to remove especially when is left unattended few days but with Alien clean effortlessly
we always begin by a good good washing
cleaning the electronic damper control carefully
https://lh3.googleusercontent.com/-2...0/DSCF8537.JPG
more cleaning
https://lh3.googleusercontent.com/-x...0/DSCF8539.JPG
more cleaning required
https://lh5.googleusercontent.com/-w...0/DSCF8545.JPG
anti rust drips
spray on brush off & rinse away with OPC
https://lh4.googleusercontent.com/-k...0/DSCF8575.JPG
before
https://lh5.googleusercontent.com/-A...0/DSCF8556.JPG
after alienised
https://lh4.googleusercontent.com/-r...0/DSCF8562.JPG
a weeks old wheels
https://lh5.googleusercontent.com/-6...0/DSCF8527.JPG
closer
https://lh5.googleusercontent.com/-E...0/DSCF8512.JPG
closer
https://lh3.googleusercontent.com/-I...0/DSCF8531.JPG
immerse amount of dust accumulated and not easy to clean but..............................
after a simple bath - with OPC
https://lh3.googleusercontent.com/-P...0/DSCF8773.JPG
before
https://lh5.googleusercontent.com/-v...0/DSCF8516.JPG
after a good bath before opti coat
https://lh4.googleusercontent.com/-E...0/DSCF8775.JPG
rims exterior before
https://lh4.googleusercontent.com/-t...0/DSCF8515.JPG
after
https://lh5.googleusercontent.com/-C...0/DSCF8781.JPG
moving to side steps area...
removing dirt trapped in between by Opti clean
center console cleaning make easier with OPTI Clean
https://lh6.googleusercontent.com/-I...0/DSCF8567.JPG
cleaning the fuel filler area
https://lh3.googleusercontent.com/-v...0/DSCF8573.JPG
a newly fitted universal Diesel filler adapter cap for all petrol station (as many comes with difference size of pump nozzle)
https://lh4.googleusercontent.com/-L...0/DSCF8572.JPG
moving in
to clean the rest with the effortless Optimum Opti clean
https://lh4.googleusercontent.com/-1...0/DSCF8547.JPG
example
before
https://lh6.googleusercontent.com/-D...0/DSCF8548.JPG
after OOC
https://lh6.googleusercontent.com/-L...0/DSCF8552.JPG
after a good good bath - we further prepare the paint surface decontamination - follow by inspection as paint need to be carefully studied and measured prior correction
https://lh4.googleusercontent.com/-H...0/DSCF8643.JPG
this enable a quick assessment of the quality of the paint finish and to verify the clear coat is not endangered or too much of clear coat being removed during paint leveling / over excessively
we discover some deep water spots etching on the paint
https://lh6.googleusercontent.com/-3...0/DSCF8586.JPG
closer
https://lh4.googleusercontent.com/-y...0/DSCF8592.JPG
Quote:
The most important thing a person can do is to find out what caused the problem and then try to avoid it into the future because you cannot continue to compound a thin, hard factory finish as you`ll go through the clear and expose the basecoat.
MIKE PHILLIPS
another water spots etch
https://lh5.googleusercontent.com/-A...520F%25202.jpg
Re: F10 brand new BMW deliver with etched water-spots damaged - restored and OPTI COAT protected
Very nicely done...was told recently in a BMW internal corp meeting with dealers that clear coat was going to get harder in 2013....
Great work KC!!!! Mamma-Mia!!!
Thanks for another Great write up.
You have me thinking very hard about Opti-Coating my black daily drive.
Quote:
Originally Posted by
Jsmooth
Great Job!
Thanks Jsmooth for your kind words
Sundaze
Thank you Sundaze for your cheers, wait no more
the best anyone can gives to your investment
Todd Helme
MUCHA Gracias
Thank you my beloved friend
You are a great leader
Got influence from all your post - keep it up
glen e
Thank you Glen
they should, the clear is so soft esp in tropics
mjlinane
Awesome work!!
Thank you my beloved friend for all your cheers along the hard way
Another great job turned out by KC :) One question. How much alien juice do you you go through?
rzatch
Thanks buddy
maybe 150 ml of 1:3 OPC dilution :bigups
AndrewBigA
nice work & writeup KC.
thanks Andrew - cos I am constantly inspires by your PASSION & determinations
:yourrock
kc`s
:yourrock
aww thanks man lol. :bigups
