Is there a proper way to clean them? I usually rinse them off with water to get as much of the wax or sealant off, and make sure that I keep the applicator and wax/sealant together to prevent cross contamination.
Printable View
I use Murphey`s Oil Soap to clean those, just like I use on my buffer pads
I soak`m in Dawn, then pour the water/soap out, add more hot water and Dawn, wash`m , rinse good, air dry...viola!
I figure if Dawn is recommended to wash the wax off the car then it ought to do a good job getting the wax/sealant out of the foam.
Works for me. :cool
:yeahQuote:
Works great
Murphey`s Oil Soap, would have never thought of that one. Will give it a try, thanks. Dawn is also another good idea, and something I already have.
I usually throw these in the wash with my cotton towels. Hot water and liquid detergent. Dry them naturally.
I usually wash mine in the sink using warm water and Dawn, then air day. I recently gave the Murphy Oil Soap suggestion a try and found that it works well too.
I keep all applicators either in the container with the product (paste wax jar) or in labeled individual plastic baggies.
I use Dawn too
Be careful storing the applicator pads in the product jars too long.
I have had some turn moldy.
It might have just been with certain products though.
I usually store them in baggies, labeled with the product they were used with.
Where do you get Murphy`s oil soap?
Another dawn user.
I think it is a pretty common grocery store/hardware store/discount store item.Quote:
Just check the household cleaning supplies.
Charles
I always washed mine in the washing machine, and they`ve been fine. Is that bad practice?
I use to throuw mine away. I didnt think you could clean them without them falling apart.
Probably not, but I don`t know if I would want all the chemicals that come out of the pads in my washing machine.Quote:
Make sure you do them with your wife`s laundry so her perfume will cover up any residual odors.
Charles
I use Megs APC+ for cleaning ALL pads.
add to sink-full of water and after soaking, agitate, squeeze, then several rinses.
All good as new!
Regards,
Deanski
