How To: Rinseless wash your vehicle.
How To: Wash Your Vehicle Using a Rinseless Wash.
Phase 1 of the Autopia-CarCare 5-step Paint Care Cycle: The Car Wash.
http://i184.photobucket.com/albums/x...af/washtag.jpg
The first step in creating and maintaining your car`s paint is to wash and dry it with precise technique. All paint systems, but particularly modern clear coat paint systems, are scratch sensitive. This means anytime dirt or grit is rubbed against the paint, even softly, it creates microscopic scratches. With enough accumulation these scratches form visible swirl marks that act to diffuse the reflected light and the paint appears dull. Larger more visible scratches form swirl marks, which are visible micro scratches that ruin the appearance of the paint in bright light. Properly washing your car greatly reduces the chances of creating micro-scratches, keeps your paint free of acidic fall-out, and removes any dirt that blankets an otherwise perfect shine. Properly washing your car using high quality materials with good technique will not only help prevent or eliminate micro-scratches, but will not strip (or may even reinforce) your existing wax coating.
There are three main types of washing methods: Traditional Washing, Rinseless Washing, and Waterless Washing. Each type has advantages and draw backs. This article will focus on using the Rinseless Washing type to clean your vehicle.
-Rinseless Washing-As the name implies, Rinseless washing uses a technique that encapsulates and removes dirt and grime with out using a high-volume of rinse water. xRinseless washing has gained popularity in recent years. Rinseless washing is ideal in areas where water is restricted or times when speed and efficiency are critical. Popular Rinseless wash solutions include Detailer`s Pro Rinseless Wash and Glossxand Optimum Polymer Technology`sxNo-Rinse and Shine. As a benefit, each of these wash solutions utilize synthetic polymer technology that not only cleans the paint but adds a layer of protection and shine to the finish, making them ideal for maintenance washing as well.x
Products Needed:
- A large (5 gallon) wash bucket.
- Wash media- A plush microfiber cloth, foam wash sponge, natural sponge, or wash mitt.
- Rinseless wash solution- Detailer`s Pro Series Rinseless Wash & Gloss or Optimum No-Rinse Wash and Shine.
- Several Microfiber Drying towels.
Additional Products Recommended:
- A second, large (5 gallon) rinse bucket.
- Grit-Guards
- Additional cleaning chemicals- A pre-rinse solution, wheel cleaner, and bug and tar remover.
Products Being Used:
Getting Started
First, start by dropping a Grit-Guard into the bottom of each Blackfire Wash Bucket.
http://i184.photobucket.com/albums/x...lesswash/2.jpg
Fill each 5 gallons of water with approximately 4 gallons of water. Add the appropriate amount of rinseless wash solution to one bucket. Detailer`s Pro Series Rinseless Wash & Gloss recommends a dilution of 1 oz per 2 gallons of water. I used a Pro Dispenser. If you don`t have one you can use the bottle cap. Each cap-full is ¼ of an ounce. Add 8 cap-fulls to a four gallons of water.
http://i184.photobucket.com/albums/x...lesswash/3.jpg
http://i184.photobucket.com/albums/x...lesswash/4.jpg
Place your wash media into the wash solution and allow to soak for 5 minutes prior to washing.
http://i184.photobucket.com/albums/x...lesswash/5.jpg
Rinseless Wash Process:
(optional) Pre-treating your vehicle prior to getting started is an optional process. Detailers discovered that by misting the surface of the paint prior to washing, with a rinseless or waterless solution they break the tension holding the grime to the car and reduce the chance of micro-scratching the paint. Detailer`s Pro Series Rinseless Wash & Gloss can be diluted and used in a spray bottle. Additionally, Detailer`s Pro Series Waterless Auto Wash makes an excellent pre-treatment. Only a light mist is necessary. Allow to dwell.
http://i184.photobucket.com/albums/x...lesswash/6.jpg
Treat any areas of stubborn bug remains or tar with Detailer`s Pro Series Cleanse-All Exterior Cleaner and allow to dwell for three-to-five minutes.
http://i184.photobucket.com/albums/x...lesswash/7.jpg
Wash and dry your vehicle a section at time. Begin with the cleaner surfaces such as the roof, hood, and upper side panels. Wash by moving your wash media, in this case a Cobra Gold Plush Microfiber Towel, across the paint gently making sure to use plenty of solution. Wring an ample amount of solution over the section to wash and move in gentle straight lines. Some of the dirt and grime will become trapped in the solution and run off the paint, some of it will attach safely to the microfiber.
http://i184.photobucket.com/albums/x...lesswash/8.jpg
After washing the section, rinse your wash media out thoroughly in your secondary (rinse) bucket and wring until damp.
http://i184.photobucket.com/albums/x...lesswash/9.jpg
Wipe using your damp microfiber cloth to remove most of the solution safely. This will leave behind a damp surface that requires light only light toweling with a drying towel to finish.
http://i184.photobucket.com/albums/x...esswash/10.jpg
An ultra soft Cobra Guzzle will remove any remaining dampness and leave the surface feeling slick and looking glossy.
http://i184.photobucket.com/albums/x...esswash/11.jpg
Re: How To: Rinseless wash your vehicle.
Repeat this process for the entire exterior of the car or vehicle until it is clean and glossy.
Pre-treating the soiled areas.
http://i184.photobucket.com/albums/x...esswash/12.jpg
Squeeze ample amount of Detailer`s Pro Series Rinseless Wash & Gloss over the panel to washed.
http://i184.photobucket.com/albums/x...esswash/13.jpg
Wash gently in a straight lines, allow the solution to flow down the paint.
http://i184.photobucket.com/albums/x...esswash/14.jpg
Rinse your wash media out in the rinse bucket then load with more solution. Wring it out until damp.
http://i184.photobucket.com/albums/x...esswash/15.jpg
Wipe up any standing water, leaving the surface barely damp.
http://i184.photobucket.com/albums/x...esswash/16.jpg
Towel completely dry using a waffle weave drying towel.
http://i184.photobucket.com/albums/x...esswash/17.jpg
Repeat the washing and drying process for the door jambs (if desired).
http://i184.photobucket.com/albums/x...esswash/18.jpg
Wheels and Wheel Wells
http://i184.photobucket.com/albums/x...esswash/19.jpg
Spray a liberal amount of Detailer`s Pro Series Tire Cleaner on to the wheel.
http://i184.photobucket.com/albums/x...esswash/20.jpg
Wash using Detailer`s Pro Series Rinseless Wash & Gloss and a general duty microfiber towel.
http://i184.photobucket.com/albums/x...esswash/21.jpg
To clean the barrels of the wheels (the area behind the spokes) wrap your wash towel around a Wheel Woolie.
http://i184.photobucket.com/albums/x...esswash/22.jpg
http://i184.photobucket.com/albums/x...esswash/23.jpg
Dry using a second, general duty microfiber towel.
Pre-treat the wheel wells with Detailer`s Pro Series Cleanse-All. The wash using a general duty microfiber towel and Detailer`s Pro Series Rinseless Wash & Gloss. Wrap the cloth around a Wheel Woolie to access difficult to reach areas. Wipe dry with a second general duty microfiber towel. Because Detailer`s Pro Series Rinseless Wash & Gloss features a high tech polymer that infuses itself on plastic it will leave behind a dark, clean sheen.
http://i184.photobucket.com/albums/x...esswash/24.jpg
http://i184.photobucket.com/albums/x...esswash/25.jpg
http://i184.photobucket.com/albums/x...esswash/26.jpg
Clean the most soiled parts of the vehicle last, as by now, the wash solution is heavily soiled and should not be used on paint.
The last step in this case is the exhaust tips, which are soiled with carbon.
http://i184.photobucket.com/albums/x...esswash/27.jpg
A light mist of Detailer`s Pro Cleanse-All Exterior Cleaner will break up carbon and make cleaning easy.
http://i184.photobucket.com/albums/x...esswash/28.jpg
Then follow by washing with Detailer`s Pro Rinseless Wash & Gloss and general duty microfiber towel.
Dry with a second, dry general duty microfiber towel to reveal a clean exhaust tip.
http://i184.photobucket.com/albums/x...esswash/29.jpg
http://i184.photobucket.com/albums/x...esswash/30.jpg
Final Thoughts:
Rinseless washing has become extremely popular to the ability to save time and reduce water usage. Quality products, like Optimum No-Rinse and Shine and Detailer`s Pro Series Rinsless Wash & Gloss offer a safe way to quickly wash a moderately soiled vehicle. As a benefit, each product infuses the surface with synethic polymers that boost the shine of the paint and increase the protection.
http://i184.photobucket.com/albums/x...esswash/31.jpg
Excellent tutorial and article Todd!
Great tutorial Todd and Thank you...
PS. When did you paint the MS3?
Quote:
Originally Posted by
rurocking
Appears to be vinyl wrap. "Why" would be the better question!:gotcha:
Great article Todd. Pretty much step by step how I wash my MZ3, except I`ll pour the wash water into a dedicated wheel bucket before doing the wheels, wells and tips.
Excellent tutorial Todd...
Good write-up thanks, going to try it on my next wash.
good info. Definately will be very helpful for people!
All I can say is THANK YOU. I am learning so much from this site. Todd great job, sir..
Nice writeup!!
What other wheel cleaners are safe to use with the rinseless wash? I know most need to be rinsed with a stream of water.
I have some Griots wheel cleaner. Could I use it with a rinseless wash? Is Sonax wheel cleaner out of the question?
Thanks.
First post btw.
armorrig
Nice writeup!!
Thanks.
First post btw.
I have never tested either of those with a rinseless wash. Detailer`s Pro Series Wheel Cleaner is designed to rinse off with little `flushing` which makes it ideal in this situation.
IRCC both Griot`s and Sonax have a neutral pH, so they should be okay (this is assuming there is no long term damage from not rinsing away all of the residue).
And welcome to AutopiaForums!!! :bigups
Todd Helme
Thanks!
Another phenomenal thread Todd! You might think seriously about making this a Sticky.....:bigups
