My new Toy
Nice, come do my carpet hehe, how much was that extractor?
I really like this thing. It don`t really eats electricity like i thought it would. The only thing that iam concern about is the "constant" temperature. It is not constant, and i don`t think it is 210F.
Does anyone have any similar realted problems with this unit.
Is there any way to clean heaters if they cloged with hard water deposits. I know mytee makes system maintainer, but anything else i should know about extractor care and maintance. Just don`t want my Toy to break:-p
Thanks everyone.
http://www.game-starter.com/pics/extr1.JPG
Run some vinegar through it every so often and that will keep the hard water from accumulating.
I have the same unit. I have only used it twice so far. I really like it, other that the fact that it gulps up 19 AMPs. Also, I have no problem with my water being hot enough. Sometimes I can barely hold onto the stainless end it gets so hot.
It looks real nice and compact compared to my HP100. The heater does heat up to 210 internally. By the time it reaches the carpet I think it cools considerably. I am using the maintainer after I add solution to the tank. The only time maintainer is not needed is when you use NO chemicals in the tank. In this case try some Flush Rinse Aid made by Steambrite.com. It will maintain the system. Also, upon rinsing it will remove any soapy residue from the carpet which means a cleaner and more natural fibers. What chemicals have you used in the machine to clean? Have you tried the Mytee HD Shampoo?
Keep us posted about all your success stories. And if ever a carpet is too cruddy try and suggest that the carpets be replaced:)
Oh, where did you buy it?
