All Purpose Cleaner, created equal?
Hey, I`m shopping around for an APC and found
1. Meg Detailer APC+
2. Meg Detailer APC Degreaser
3. Simple Green
I noticed the Meg`s differ by "Butyl" formulation.... I really want something I could use for the Engine, Tires, Carpets, and Velour. My main concerns are irritant (mostly smell :fart and respiratory). I know most of you guys use the APC+, what are some dilution ratios you use?
On a seperate note, what does engine kote do? I gather its an engine protectant from properautocare. Thanks for all the replies.
Re: All Purpose Cleaner, created equal?
3. Simple Green
It is probably a good idea for you to follow Meguiar`s recommended dilution ratios for APC+.
Now, having said that, I happen to use a mix of 10:1 water/APC+ for just about everything. Carpet, mats, cloth upholstery, vinyl, tires, wheelwells, and engine compartment. My vehicles are not usually too dirty and that ratio might not be strong enough for really dirty engines or tires. In fact, I usually can just wash my wheels, tires, and engine with regular car wash soap.
APC+ seems to do it all for me. I think you would be happy with it. The $11 dollar gallon of APC+ makes 10 gallon of cleaning solution so it is priced right for the high volume user as well as us hobby detailers.
Charles
Re: Re: All Purpose Cleaner, created equal?
Quote:
Ditto. The same general dilution covers almost all my needs as well. At 10:1 APC+ is even safe if you get it on painted surfaces (although I still wouldn`t let it sit there too long). If used for engine degreasing a stronger, 4:1 dilution will work better.
I`ve found a different Meg`s Detailer Line product for use on wheels that I like better than APC+. Meg`s Citri-Gel diluted at 1:1 works very well on wheels/brake dust and is supremely safe. Plus since it is a gel like product it clings to vertical surfaces instead of running off like APC+. The cling helps dwell time and allows the product to do the work instead of the detailer and a scrub brush.
Between APC+ and Citri-Gel all bases are covered.
