I was wondering if any of you using this heated model. Also does anyone have this model upgrade to 3 stage. It seems like some site offering 3 stage for heated model, which is 137" of lift.
http://www.rotovac.com/sp/images/myt...able_large.gif
Printable View
since 2001 and I have serviced it each year for under $100 ...
Still performing like new !!! Knock on wood !!! I really like the way the 2 stage vac has performed and will buy another this year !!! Very happy with the 8007 !!!
2 stage i think $800 -heated
3 stage ($100 more) at clean brite website. - but it looks that this is the only web site that offer that :dunno
Clean Dean:
in one of you thread you did i think camry (if iam not mistaken).
do you like the results or you wish you had better lift and capacity?
http://www.game-starter.com/pics/dirtycarpet.jpg
http://www.game-starter.com/pics/cleancarpet.jpg
I spent about 3 hours on that interior, and I believe that more lift from the vacuum would not have made a difference in the end results !!! If you look at the carpeting you will notice a unbelievable build-up of an "oil-like substance"... I had to use Simple Green full strength to break this substance down and enough elbow grease to scrub the deck of the Titanic before I extracted. The 3-stage vacuum may have gotten the same job done faster but in my opinion not better. BOTTOM LINE... That car needed NEW CARPETING !!!
Thanks a lot. I think i will go with mytee light then. It is little beat cheaper.
I don`t understand why people let there cars get that dirty. When you could just buy a rubber mat that would protect it. Those are the same people that complain when you can`t get the stains out.
I always tell them that I am a detailer not magician
I agree with you Beemer
:bigscream :bigscream :bigscream
http://www.detailcity.com/forums/sho...=&pagenumber=3
I think it was not bad, consider that it has been 3 years sine you bought it.
What do you think?
I am expecting hte freight truck to stop by any day with that unit pictured. Well maybe not the same exact model but, it is the same shape only grey all around. The model is HP-100. THe unit retails for $1500 and I got it at a steal for $700. It is heated, has a 2 stage vacuum with 137" lift and 100 psi pump. It is also a 6 gallon. The nice thing that they are doing for me at the place i bought it is throwing in the 15` hose and 3" detail tool. Also I am going to order a stain fighting chart which explains the chemicals and proces s of removing every stain imaginable.
Ryan
Where did you get it for $700 and it is a steal at that price...make sure it works and get the warrnety!!.
I trust Dwayne, so when im ready I will order it I will threw PAC, also get 10 percent discount and know it will work...
jeff
Ryan:
Where did you get your Hp-100?
Maybe it is Hp-60 not Hp-100. Hp-100 does not have 6 gallon solution and recovery, it has 12 gallon.
So maybe you got Hp-60?
Sparkle Auto
No. It is definitely the HP 100. I could have been wrong with the solution tank capacity. Anyway, the place that I bought from is Sparkle Auto out of Kansas. Someone had this, under a year old, and decided to upgrade to a much larger unit. I got the unit for $700 + freight.
