Hi, all.
The conventional wisdom is that if the paint isn`t smooth, then you begin your prep by using clay/lube. Is that right?
Well ...
What happens if, try as you might, you can`t get the paint smooth with clay. I must have some really embedded contaminants in my paint. :( The problem area is the rocker panels just behind each wheel.
Is this the time to use an abrasive product with a PC? :bigscream
