Which step do you people do first? Clay, or use a cleaner to get rid of scratches? If you clay first, do you wash the vehicle afterwards or do you go on to the next step?
Printable View
I clay using Meg`s #34 Final Inspection as a lube ... so clean-up is easy with out a second wash.
I polish second ... Some of the junk that the clay pulls out (for lack of a better term) will end up on your pad otherwise. Just my thoughts ... I am sure there are others!
Well, I already answered this one elsewhere :crazy Kinda like a deja-vu!
My preference is to wash first, then clay with a fresh bucket of wash soap for lube. I re-wash each panel as I finish claying. Rinse then dry. Afterwards, I would pull out the appropriate paint cleaners, swirl removers, or polishes.
Wash, then clay with a quality lubricant (Adam`s Detail Spray). I leave the residue on there, and do my initial polish right over it.
It comes out great, and save time from rewashing.
My routine exactly! :bigupsQuote:
I basically do the same thing Nick has described.
Do a preliminary wash, then thoroughly dry the vehicle, then clay it.
Some people rinse/wash it again after it has been clayed, but unless there is a justified reason to do so (like obvious spots/blemishes from the lube) i dont think its necessary.
Goodluck.:)
I`m with NICK and BOSS I use a good QD spray after the wash and dry. Then straight to the SWR or polish.
I`ve always wondered about those that use soapy water then have to re-wash again.
I mean that it takes me 5 to 6 hours for a full detail and that seems like just more time.
It`s winter, no water available, so after I clay I use Spray and Wipe, then Pro Polish, then EX, and will be changing to Ex-P with the next full detail.
