any u guys use da 2 bucket system one bucket for da suds:beer and one bucket for rinse water:google
Printable View
I use just a bucket for suds and then rinse with a hose. Not sure what the rinse bucket is for? If you are try to keep your mit clean just make sure to dip in the suds often. It seems like it would be more efficent...
what i use the extra bucket for is to keep just plain water in it to rinse my mit out often to get all da grit and other foreign objects out of my mit keep from scratching:duel
I use it, and true Clean4u, it will keep from scratching.....look at how clean the suds water is when you are done compared to the 1 bucket system :wait
I use just one bucket making sure i dip and shake out my mit often. It works well for me. but if you are more comfortable with two bucket there is no harm in it.
I use 2 buckets. It helps me from introducing new swirls.
The 2 bucket method is far superior. Its a simple test, try it yourself.
Keeps the soapy water clean. Look at the color of the rinse water!
Jim
Two bucket is the safer method.
I use the 2 bucket method. The 1st time I read about it I thought it was crazy. Well I tried it and I couldn`t believe how much dirt was in the 2nd bucket. The 2 bucket system is the way to go for me.
I tried it for the first time over the past weekend, (even bought 2 new buckets just for the occassion) and it does make a difference...IMO. I discovered that the 2nd bucket (Rinse Water) really does release comtaminants from the mitt (I use a wool mitt). Dust dip the mitt into the rinse water and agitate the mitt to release the dirt trapped in the mitt. It takes a couple extra seconds to do, but isn`t your car and your clients worth the extra couple of minutes? It will help keep the finish protected longer and not introduce addition micro-swirls into your work surface.
Hey 57chevy, I like your new Signature line :lmfao
2 buckets here for a long........ long ......... time! Longer than I`d care to mention! :D
:beer Thanks for all da replys .......... any suggestions or ideas for me please let me know Thanks:jump
