Stoners More Shine Tire Gloss
Over the weekend I ran out of Stoners IG, off I go to the local Kragen....While there I scanned threw all the stuff and the sale stuff...nothing other than the Stoner More Shine caught my attention...Aerosol can or liquid spray nozzle..I tend to like non-aerosol products feel like I get more..
The product is a spray on..the texture of it on the tire is somewhat milky but coats the tire very even...Dry time was quick seems like it set up pretty well in 10 minutes, and was completely dry and ready to go in 20 or so...The shine is very wet looking..I suppose that you could reduce this down by buffing the tire a bit or applying by hand with a damp sponge...The finish is non-greasy it drys hard on the tire..so there is no sling...as for its durability I don`t have a clue yet but will see over the next week to two...if its anything like the other Stoners line it will be a fairly durably long lasting product.
I sprayed about 4 to 5 pumps to each tire, how that equates to price per tire I don`t know just yet..I did 2 cars and one large truck and there is still a large amount left.
Plus
Quick dry time
Even coating on all surfaces
Fast application
no sling
non-greasy finish
Minus
Over spray on the rim
Kind of expensive (gallon pricing would be appealing)
Cost was $4.99 for 22 oz
I say that if you are looking for a quality tire shine that gives that wet look this is one for you
Re: Stoners More Shine Tire Gloss
Nice review Dave...
I am like you and prefer sprays to aeresol as aeresol cans have great difficulty even with a slight breeze, the product goes every where.
But even with sprays the tend to get on the rim, causing more cleanup...
I always take my tire dressing and pour it into a cup and then apply it with a painters brush..I haven`t seen to many OTC products come in sizes other then the standard sold at stores...I am curious to see the durability.
The way that I work around the clean up of the over spray on the rim...I put the wheel sealant on then spray the tire, carefully then once I remove the sealant I clean the rim of over spray at the same time
Quote:
Originally Posted by
Beemerboy
Makes sense...I never thought of doing it that way...
I guess that Tuna is paying off:D
Stephan
We the only two on the site today?
Beemerboy
Yes...which is good incase someone new signs up we can greet them:D
Stephan
Yes...which is good incase someone new signs up we can great them:D
that would be "greet " them ...:notme: :lol2: :welcome:
Did you get any sling from this product, ole chap?
Poorboy
thanks...:wall:D
JaredPointer
Only if he drives it.
JaredPointer
JP
none that I could see....I put this on about 40 to 60 minutes before I finished the car so by that time it was well setup...currently I am using a product that is very similar to B-n-B if I spray it on, some of the tires hold the liquid certain areas...little groves and such....and that`s doesn`t dry to fast so even after and hour once I drive the car it slings from those areas....this one didn`t
I`ve used it for years but prefer the aerosol. It also works wonders on wheel wells, engines, and plastic air dams like those beneath the front bumper.
RTexasF
Yea I could see where it would work real well on those areas as well...again its expensive for that type of use when I can get gallons of water based dressing for much less...I would like to think that this Stoners MS might be available in gallons, but would have no idea where to look
Anyone?
Beemerboy
Anyone?
I couldn`t find anyplace that sold it by the gallon, but Stoners itself sells them it packages...
Detail your car like the pros with Stoner car care products to get more shine in less time. Available at automotive retail stores
12 aerosol cans is $35 delivered to my door from Stoners. I don`t consider that expensive at all.
